leaking problems
My 40 is leaking from everywhere. The rear diff is leaking, I removed the drive shaft and I can't get the pinion nut off to save my life. It was staked, I straightened it out and tried everything. I sprayed it with multi-purpose lube, used a LONG cheater bar, impact wrench everything. I just run the tires up over the 4x4 I used to chock the tires. How do I remove this?
My transfer case is also leaking. It's leaking form the expansion plug. Does anyone know how to fix that, short of taking it out and rebuilding it?
To top it off I'm leaking water and oil from the sbc 350... that's another post.
Thanks for any advice you may have.
