Old 11-06-09, 10:53 AM   #1 (permalink)
4WFAB-N'
MT TUBEKRAFTER's Avatar
pinion ?
my question is ...is there a size difference between early and late model pinions or are all pinions the same size through the years with the only difference being the coarse to fine spline change ?and can I run the early 40 R&P In my 60 series axles?
MT TUBEKRAFTER is offline   Reply With Quote
Old 11-06-09, 11:35 AM   #2 (permalink)
camcruiser13's Avatar
different ratios, but if you took both front and rears you should be fine
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
DIY Beadlocks
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 11-06-09, 04:41 PM   #3 (permalink)
Bret's Avatar
The diffs are all interchangeable, in the pinion arena you have coarse spline/fine spline at the flange and crush sleeve or shims for the pinion preload. I would stay away from the coarse pinion if possible, and would use the shims vs. crush sleeve. Sorry I don't remember the years for spacers/sleeves.
Bret is offline   Reply With Quote
Old 11-06-09, 08:33 PM   #4 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
Nope, no size difference.
The major fitting issue with installing the old coarse-spline (pre-1978) 4.11 ratio R&P in a 60 Series is the pinion flange bolt pattern. The drive shaft bolt pattern on the 60 Series is wider, IIRC, than the one present on coarse-spline 40 Series diffs.
If you want 4.11 diffs in your FJ60 the third members from a FJ62 would be the best swap for you. Or, get a set of new 4.11 R&P gears. These are all fine-spline, and will work with your stock pinion flanges.
Good luck!
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
