Old 11-01-09, 07:21 PM   #1 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Home Brewed U-bolt Flip.
Hi All:
Been working on a home-brewed u-bolt flip for my SUA FJ40.
Here is a pic of a "mock-up" done on a spare rear axle tube. I'm using those GM P/U u-bolt plates.
The only reasons I can think of to have a bottom plate under the leaf spring is to protect the spring center bolt and to align the u-bolts under the spring.
Any opinions or comments?
Thanks!
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
Old 11-01-09, 07:27 PM   #2 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
I think that bottom plate is important and keeps the spring pin aligned, and keeps the u-bolt s from spreading. Also recesses the u-bolts What is your top plate? Looks like a Chevy piece.
Andrew
Old 11-01-09, 07:59 PM   #3 (permalink)
X2 on what is that top piece. Do you have have year and model we can all go out and find? Also would agree w/ the thought on the bottom plate (or lack thereof...) Seems like the lower plate would be e z to fab. I like it. Good work!
LAMBCRUSHER is offline   Reply With Quote
Old 11-01-09, 08:19 PM   #4 (permalink)
Local Diesel Fanatic
CruisinFJ60's Avatar
TLCA# 16781
he could easily take a peice of steel and cut 2 slots for the u bolts to keep them from spreading tho i dont think that would be much of a problem.
If you flipped the center pin to where it was into the little bottom mount seems like that would hold it in place just fine.
looks good. i dont really see any issues as long as you can hold the axle from shifting on the springs.
[O]=TOYOTA=[O] = Mo Betta!
**84 FJ60 "Fiona", OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap**
**82 BJ42 SR and some 33x10.50-15's**
91 Honda Civic Hatch "Fry" with a JDM B20B CR-V Engine, with some bolt ons... Oh and it might have some nitrous there somewhere as well...
01 Dodge 2500 "Clifford" 5spd 4 door 4x4 Cummins Turbo Diesel with 4" turbo back exhaust, Quadzilla Adrenaline w/ Pulse, 90hp sticks, Valair Ceramic Clutch, Raptor 150 lift pump, and some 285/75/16 Treadwright MTG's Dyno'd 409.1HP/742.6FT-LBS on 4-11-09 Still NOT Enough POWER!!!
Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
I of course guarantee all of my work to be a professional installation / service.
CruisinFJ60 is online now   Reply With Quote
Old 11-01-09, 08:37 PM   #5 (permalink)
Dog is my co-pilot.
TLCA# 6446
Hi All:
Look in this thread for the part numbers of the upper u-bolt plates (I'm using junkyard versions.)
http://forum.ih8mud.com/40-55-series...-build-up.html
Regards,
Alan
Old 11-01-09, 09:03 PM   #6 (permalink)
Nice! I think you'll be ok without the bottom plate...but I have a suspicion that it will help with centering the leaf spring when you hit something hard. Also, a bottom plate may act as a "ramp" on rocks etc so they slide right down the spring instead of possibly stopping at the u-bolt.
Tankota is offline   Reply With Quote
Old 11-01-09, 09:15 PM   #7 (permalink)
Here's what I did with mine, the top bracket is from a toyota pickup, I built the bottom plate from spare steel. I ended up ditching this design when I had to put in 12* shims and I couldn't find u-bolts long enough. I'll go back to it when I find the u-bolts I need.
Seth_O
"She may not look like much, but she's got it where it counts."
Originally Posted by Vicm View Post
A 40 is like a wife , everything else is just a GF.
'69 FJ40 "Lucy": '77 2F; SM465 + NP203 + 3spd t-case; SR + OME 2.5"; 4WDB; PS; 100" WB; bucket seats; on-board air; still needs body work :(
Seth_O is offline   Reply With Quote
Old 11-02-09, 01:14 PM   #8 (permalink)
jcj_78FJ40's Avatar
I have the same set-up. I have been running them for a couple of years now w/no issues.
X2 on the bottom plate will keep your center pin from getting buggered up and will keep the U-bolts in place as they get dragged over rocks n stuff.
Keep in mind this MOD may be better suited for aftermarket springs since they are usually not as wide as stock 40 springs.
Looks great!.. keep up the good work
78 fj40, 4" lift, Scout PS, ARBs, SM465/3spd TC
91 FJ80-stock for now-future expedition truck
jcj_78FJ40 is offline   Reply With Quote
Old 11-02-09, 02:40 PM   #9 (permalink)
The Anti-Leafer
LC_Hamma's Avatar
TLCA# 3343
Wow! Welcome to 1997 Yeah you will need the bottom plate as your u-bolts will spread out & your center pin will egg the leafs.
LC_Hamma is offline   Reply With Quote
Old 11-02-09, 02:54 PM   #10 (permalink)
Geezer
spotcruiser's Avatar
TLCA# 10016
Hey Alan,
You can buy a couple chunks of steel and build your own bottom plates.
http://seattlecruiserheads.com/
spotcruiser is offline   Reply With Quote
