11-01-09, 11:02 AM
Aussie Locker in front axle - REAL TIME HELP
I already installed my Aussie in the rear of my 76' and am now starting on installing one in the front axle.
My first question though is: since I have a Marlin tack on my front axle shafts, how far do I need to break down the front axles IOT slide the shafts out and remove the third member? Do I still have to completely tear the front apart like when I did my FDB conversion or is it simpler with the Marlin tack?
Thanks!
11-01-09, 12:02 PM
Local Diesel Fanatic
the mar tack allows you to pull it all apart at the knuckle so you can quickly swap a birf since no clips are holding it in anymore it will slide out of the hub, and all the bearings can go untouched.
so since you have this done if it were me id just pull it apart at the knuckle and slide the inner / birf out enough to drop the third.
[O] =TOYOTA=[O] = Mo Betta!
**84 FJ60 "Fiona", OME springs, anti inversion lift shackles, 33's, Front aussie, Rear Detroit, 4.56's, and exhaust..... For Now.... ROTW, 2F-E Swap**
**82 BJ42 SR and some 33x10.50-15's**
91 Honda Civic Hatch "Fry" with a JDM B20B CR-V Engine, with some bolt ons... Oh and it might have some nitrous there somewhere as well...
01 Dodge 2500 "Clifford" 5spd 4 door 4x4 Cummins Turbo Diesel with 4" turbo back exhaust, Quadzilla Adrenaline w/ Pulse, 90hp sticks, Valair Ceramic Clutch, Raptor 150 lift pump, and some 285/75/16 Treadwright MTG's Dyno'd 409.1HP/742.6FT-LBS on 4-11-09 Still NOT Enough POWER!!!
  Need A Cruiser Mechanic? Zismine4life@yahoo.com <----(Me/Trent)
I of course guarantee all of my work to be a professional installation / service.
11-01-09, 01:14 PM
There is enough variation in the length of the side gear splines of the locker and the OEM that the placement of the Martack may be different. This is worth checking before you get it all buttoned up. you don't want the Martack to be so close to the end of the shaft that you can't get the knuckle reassembled.
11-01-09, 01:42 PM
Good point i didnt even think of this!
Im sure it will prolly be fine but check it anyway.
11-02-09, 06:54 AM
Thanks for the help. I got the shafts pulled out, the diff out and the locker in. No issues with the location of the Martack. Thanks guys!
