Old 10-31-09, 09:44 PM   #1 (permalink)
bigneily's Avatar
TLCA# 18252
castor angle?....how
hello fellas , been tryin to figure it out by reading old posts without much luck how do you check your castor, i'm assuming with a magnetic angle finder, but where would you attach it? and what would be considered acceptible on a soa rig? my spring shackles are not stock they are longer but i'm not sure by how much since i don't know what stock length is? tryin to get to the bottom of the alignment issue....
75 fj40 soa, saginaw power,disk fronts,350 small block,warn 8274,35" mt's, all blown over with some rustoleum
bigneily is offline   Reply With Quote
Old 11-01-09, 05:29 AM   #2 (permalink)
Scroll down to the bottom of this link for stock shackle sizes:
Specter Off-Road Land Cruiser Parts - Page 288 Shackles - Aftermarket
'81 FJ40 Project
'07 Tacoma 4WD SR5 Doublecab
Splangy is online now   Reply With Quote
Old 11-01-09, 05:49 AM   #3 (permalink)
It's covered well here: http://forum.ih8mud.com/40-55-series...nt-camber.html
3doghouse is offline   Reply With Quote
Old 11-01-09, 08:26 AM   #4 (permalink)
nspctr1's Avatar
I paid twenty five bux for a alignment shop to determine mine.
'73 FJ40 with 283 sbc, mini discs, 33" BFG's, Family Cage, Autometer Phantom Gauges
nspctr1 is offline   Reply With Quote
Old 11-01-09, 08:44 AM   #5 (permalink)
total rice
dgangle's Avatar
TLCA# 10793
what did you ever end up doing?
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000 ROTW
2007 4 Runner SR5 4WD - stone stock daily driver
TLCA#10793
"The advent of the internet has permitted stupid people to propagate their stupidity WAY too easily, all with a position of self-proclaimed authority preying on peoples' ignorance or stupidity. Everyone with a keyboard is an expert." UNKNOWN
dgangle is offline   Reply With Quote
Old 11-01-09, 09:32 AM   #6 (permalink)
bigneily's Avatar
TLCA# 18252
thanx for the links gents i measured my shackles they are 4 3/4 in long, now for a soa rig what do you fellas think the caster angle should be or close. my cruiser darts all over the place while everything looks tight, i think my caster angle is wrong, so i'm going to try to remedy the shatty handling....
Old 11-01-09, 09:46 AM   #7 (permalink)
total rice
dgangle's Avatar
TLCA# 10793
+3 to +6*, depending on who you ask.
TLCA#10793
Old 11-01-09, 09:57 AM   #8 (permalink)
Pin_Head's Avatar
+ 2-3 degrees is appropriate for cruisers with power steering. +1 is the stock value. Some people run more, like 5-6 degrees, but I don't think that this is a good idea for trucks that you are going to drive on the highways at high speed. High caster angles decrease the front tire contact patch in turns, making it more likely to slip on wet pavement. It also increase the wear on the edges of the tire. I have never seen any vehicle or truck with more than 3 degrees of caster specified.
Pin_Head is offline   Reply With Quote
Old 11-01-09, 10:11 AM   #9 (permalink)
bigneily's Avatar
TLCA# 18252
and what i also picked up from reading the supplied links is that it is almost impossible to get a accurate caster reading, unless you disassemble the outters and measure off the bare knuckles above the races, or have a alignment shop give you your #'s am i correct...
Old 11-01-09, 10:21 AM   #10 (permalink)
Pin_Head's Avatar
If you have a stock axle, you can measure off the pinion flange, which should be 90 degrees with respect to a flat pavement surface. If the pavement isn't flat, you have to subtract its angle from the pinion measurement. The accuracy of these measurements is probably about +/- 1 degree, so it is good enough to tell if your caster is incorrect.
Old 11-01-09, 11:25 AM   #11 (permalink)
bigneily's Avatar
TLCA# 18252
my diff housing is cut and turned, so this wouldn't be considered stock, am i correct...
Old 11-01-09, 12:54 PM   #12 (permalink)
Pin_Head's Avatar
Correct, cut and turn is not stock.
The only relatively easy places to measure would be the machined flat spots on the top or bottom of the knuckle.
If the knuckles were cut and turned, then the caster should have been taken into consideration in the job, because that is the point of doing it.
Old 11-01-09, 02:46 PM   #13 (permalink)
bigneily's Avatar
TLCA# 18252
thanx pinhead....
Old 11-02-09, 09:39 AM   #14 (permalink)
i used to do alignments everyday for five years, there are plenty of cars over 3 degrees caster, bmws, benz, euro cars are almost always 6-7 sometimes up to 9 degrees. most truck have max 4 degrees. id get it around 3 degrees and put on a steering stab.
ullose272 is offline   Reply With Quote
