Old 10-30-09, 02:33 PM   #1 (permalink)
Fj62 into a Fj40 1978
I have a FJ62 that i am parting out. I took the axels out and those axels are in perfect condition. I have not check how my axels on the 40 are but I will say that they need to be rebuild. I am also thinking about installing the 3F cam on the 2F and all that. My project supposed to be a original restoration but I can not avoid to see all these goodies and not use them on my 40. Now my questions.
- Can i use the 62 axel without too much cutting and welding?
- Will the 62's transfer case bolt to the 4 spied in the 40?
- Is it worth it to do all this
I am also going to use the steering pump and steering box and the brake. I guess i can also use the master cylinder and the booster.
What did you guys think?
Roxx is offline   Reply With Quote
Old 10-30-09, 02:43 PM   #2 (permalink)
bad_religion_au's Avatar
the 62 axles need alot of welding to get to fit under a 40.
what year is your 40? that'll determine if the T case will go in.
What can you do when you wake up and realise you sacrificed everything you ever wanted in life for the sake of progress?
bad_religion_au is offline   Reply With Quote
Old 10-30-09, 02:57 PM   #3 (permalink)
40
It is a 78
Old 11-02-09, 09:15 PM   #4 (permalink)
then it won't
Old 11-02-09, 09:24 PM   #5 (permalink)
grant5127's Avatar
Re-locate the rear spring perches and out-board the front spring hangers..........E-Z nuff.........
|^^^^^^^^^^^^^^^\ ||__
|.......PBR BEER TRUCK.... ||""\_____\
|_____________________/||__|___|
The Beer Truck, that ran over Bunny.....
(\__/)
(")_(")
grant5127 is offline   Reply With Quote
Old 11-03-09, 08:52 AM   #6 (permalink)
Is that it. there is not other modification.
I am going to take the measurements and see what comes out to be.
Old 11-03-09, 10:43 AM   #7 (permalink)
CottonLand Cruisers
Bodean's Avatar
TLCA# 3164
The 40 Drive shafts will work if you change the flange in the 3rd or rotate the yolk and re drill the holes for your bolts.
Jeff
CottonLand Cruisers
Whitetrash of the Elwood Chapter
I PRINT T-SHIRTS!
78 FJ40 4" Skyjackers, 35" MTR's, Detroit, Metal Tech cage, 8274, Choctaw Sliders, Mini truck P/S, 2F!!
TLCA #3164
USAF - POL 1987 - ?
"Caliente Maldito"
Bodean is offline   Reply With Quote
Old 11-04-09, 08:42 AM   #8 (permalink)
will need to work out shocks/shock mounts too. 60's shock mounts are on the spring plate...
