Check your peddle hight first with spring removed about 3/4" Freeplay @ the peddle if not adjust peddle under dash .
freeplay at the through out bearing with spring removed there should be no contact between the T/O bering and the clutch fingers/diaphragm with clutch released only 0.16 in gap.
With the slave bolted up The Gap between throughout baring and the clutch fingers/diaphragm you can run the adjuster nut to just make contact with fingers/diaphragm run up the lock nut with spacer/feeler gage between 0.16 in and remove feeler gage or spacer or eyeball back off the adjuster nut wile holding the lock nut in place tighten the adjuster-nut ageist the lock nut check again, you may have to do this a couple of times. don't forget to replace the tension springs hope this helps
Good luck
