Old 10-26-09, 02:10 PM   #1 (permalink)
slickrock's Avatar
TLCA# 18284
need picks of front outboarded spring perches (not reversal)
After I did an SOA on my 40 with a 60 series front axle, I need to move my front spring shackle mount out 1" more. It was already outboarded 1.75" but, I had to move the axle perches out even more than when I had an SUA set up. Since it looks like I will have to make some type of frame box for the shackle mount, I could use some ideas. Thanks.
Father of Slickpebble . . . 8/73 FJ40, flipped F/R Springs (almost 100" WB), SOA, 60 series front axle, grooved 35 BFG muds, fully locked, 60 series power steering, full cage, 60 series ignition, hydro assist in future: AKA Slickrock or Dusty's tow truck.
www.centralvalleycrawlers.org
forum.ih8mud.com/ca-central-valley-crawlers
slickrock is offline   Reply With Quote
Old 10-26-09, 06:40 PM   #2 (permalink)
EWheeler's Avatar
Make your own frame outboarding bracket, similar to the Ruffstuff brackets. It will give you a wider area to weld the shackle hanger to. I make a similar bracket for my front spring hanger but am SOA. It is the same concept.
My bracket:
Ruffstuff outboarding bracket:
Frame Outriggers 4.5" [0692200] - $57.00
1980 FJ40 work in progress: http://picasaweb.google.com/evantwheeler
EWheeler is offline   Reply With Quote
Old 10-27-09, 08:53 AM   #3 (permalink)
slickrock's Avatar
TLCA# 18284
That is perfect. exactly the type of mounts I have. (but I am not shackle reversed). It looks like you used a piece of angle and another 1/4" piece of flat stock for the 45* piece?
Much more simplier than I was thinking.
Old 10-27-09, 10:46 AM   #4 (permalink)
EWheeler's Avatar
Nope, just had some 4x4x1/4" box left over from my front bumper that I cut for the gusset. The two big boys on the left:
In place:
The only difference is that you will want to box in the bottom of the gusset to give yourself a mounting surface flush with the bottom of the frame for the shackle hanger to mate to. Post up pics of what you end up doing.
Old 10-27-09, 06:32 PM   #5 (permalink)
Plowboy's Avatar
What about using a rear 40 hanger on the front? Then you just have to figure out the shackle hanger
78LC40, sbc 327, PuPs, Aussie Locker, 4wdisc. 1948 bradley trailer
Plowboy is offline   Reply With Quote
Old 10-27-09, 07:14 PM   #6 (permalink)
jefishing's Avatar
Ewheeler that looks nice and very clean. That is also one bad A$$ bumper.Where did you get the front hanger at and did you use the stock hanger for the rear?
68 fj40 2f, front disks, 4" lift , SR in front, 1 1/2 shackles, 35" pro comps
jefishing is offline   Reply With Quote
Old 10-27-09, 07:40 PM   #7 (permalink)
EWheeler's Avatar
Thanks for the comps.
Spring hanger & shackle hanger are from Ruffstuff Specialties. Best customer service of any of the pre-made fab parts bar-none and, he is a cruiser guy to boot! Use the pirate discount for 10% off.
Toyota FJ40 FJ45 FJ55 FJ60
