Old 10-26-09, 08:50 AM   #1 (permalink)
pghfj40's Avatar
TLCA# 13361
Anyone upgrade E-brake Mounting Bolts?
Ok, in yet another display of sheer brilliance, I've driven through my Ebrake and sheared the 4 backing-plate-to-xfer mounting bolts ... for the 2nd time.
As this is expensive (also pops the $80 brake cable) and time-consuming (not to mention frustrating & embarassing)... and knowing that I'm unlikely to get any smarter... I'd like to dummy-proof it to prevent future re-occurrence.
I would think the design should allow the ebrake to slip first (I'm glad it holds the vehicle, but geeez!). I'm surprised Toyota chose just four little 8mm bolts at such a high stress point.
Is there a stronger bolt/stud out there? Or has anyone drilled & tapped the speedo housing for the next larger size bolt?
Will this just move the point of failure to the xfer case or speedo housing?
Other thoughts? Experience?
'70 FJ40
pghfj40 is offline   Reply With Quote
Old 10-26-09, 09:07 AM   #2 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
Originally Posted by pghfj40 View Post
Other thoughts?
I have seen 12.9 hardness 8mm bolts shear off in that same application. There is not significant meat around the bolt holes to take them to 10mm.
Train yourself to release the parking brake every time; it is by far the easiest solution to this issue.
Old 10-26-09, 09:33 AM   #3 (permalink)
Coolerman's Avatar
TLCA# 13645
Does your E-Brake on light not function? You could wire a buzzer in it's place...
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 10-26-09, 07:17 PM   #4 (permalink)
I was thinking the same thing about the light, or install another light in a very obvious place.
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 10-27-09, 10:11 AM   #5 (permalink)
pghfj40's Avatar
TLCA# 13361
The buzzer's a good idea, except if I installed one, the first thing I'd likely do is disconnect it!
The brake warning light works... I've never *driven* it with the ebrake on, that's not the prob...
I got distracted while parking on a hill: ebrake on and in first gear (as backup to the ebrake--tho clearly that was unnecessary)... Normally one would shut the engine down first then let the clutch out, but this time I flubbed it and let the clutch out quickly with the engine still on and BANG!
BTW--it's got an SM420: so 2x the stock torque there. Still I'm surprised it could sheer them at idle. I wonder if a couple of the bolts hadn't already failed.
'70 FJ40
Old 10-27-09, 10:17 AM   #6 (permalink)
Poser's Avatar
TLCA# 1856
Garage
I got distracted while parking on a hill.
Would appear that you understand why it occurred.
Not likely. This has been accomplished with a stock three-speed transmission.
Old 10-27-09, 10:23 AM   #7 (permalink)
I upgraded mine to 8mm studs. No idea if this helps or not but from my nuts/bolts experience, studs are usually rated higher unless you are going out of your way to get super high strength bolts
-1971 FJ55: 6.0L-NV4500-doubler, SOA, D60s, ARB'd... and cupholders
-1972 extra cab FJ45... 10 year project with a BB cady... DOA 08
-1999 Tacoma for Sale: Sac, CA $6k (clicky link)
Lil'John is offline   Reply With Quote
Old 10-27-09, 09:00 PM   #8 (permalink)
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
"LilJohn" any idea what length 8mm studs you used?
Thanks!
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
"The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
Josie'sLandCruiser is offline   Reply With Quote
