10-19-09, 10:20 AM
slave cylinder always going bad?
I have a 1972 FJ40 3 speed manual. Everytime I go wheeling my slave cylinder goes out. I believe the cylinder is the orginal, maybe not, but 3 times in one summer. What should I do?
Give it a try or get out of my way!
10-19-09, 10:26 AM
450,000+ mile club
are you rebuilding it each time...or buying new one each time?
10-19-09, 11:01 AM
Since replacement cylinders (and even rebuild kits) for the early slave cylinder are difficult to come by from local parts stores, there is a good chance it was replaced with a later slave. It all bolts up and works fine, but the bore is smaller. Sombine a smaller bore with the big-bore master cylinder, and you have the potential to over-extend the slave and blow out the seal.
I would check that before you get any further with replacing or rebuilding parts.
-Eric
64 FJ40, slightly modified.
96 LX450, locked.
10-19-09, 11:26 AM
Rebuilding.
10-19-09, 11:42 AM
Buy oem from toyota. Also have on hand a master if it goes. My 1977 slave went out on the trail in '03 and I put a new oem mc and slave in it. As I recall, they weren't all that much $. Done deal, no problems since. I always carry a spare new oem slave just in case, but haven't had to use it.
'77 FJ40: HFS, 33's, Locked and Low'd
10-19-09, 04:36 PM
If you find you have the original MC & Slave cylinder, it may be a good idea to hone the cylinder for a few minutes with brake fluid before reassembly. When i started doing this, I found out my slave cylinder seems to last longer.
ty
'79 Pig-"Inoshishi"
'69 FJ40-"Da Roofless one"
10-19-09, 05:27 PM
TLCA# Associate Member/Sponsor
A. Avoid Chinese
B. Don't mis-match with Toyota, get exact for your year!!!
Downey's gone,
Jim isn't!!!
10-20-09, 07:57 AM
The title says 1972 but the stamp on the vehicle says 1971. Which year should I go by?
10-20-09, 08:10 AM
450,000+ mile club
71-72 are the same:
31470-60021
ToyoDIY.com
Item Number MSRP Core Price Price
3147060021 $58.14 $0.00 $46.51
CYLINDER ASSY, CLUTC
10-20-09, 03:19 PM
#10 (permalink)
71-72 are the same:
31470-60021
ToyoDIY.com
Thank you
11-04-09, 05:38 PM
#11 (permalink)
Ok I have an oem from toyota, now my question is; Is it ok to use brake fluid instead of clutch fluid? Is there a difference?
11-04-09, 05:42 PM
#12 (permalink)
I've only used brake fluid......not familiar with clutch fluid? The real experts will chime in shortly.
___________________________
69 Fj55
I been warped by the rain, driven by the snow...
11-04-09, 05:53 PM
#13 (permalink)
just bleed it every few years or year , keep moisture out of it . #1 killer of hydraulic clutch and brake components is water in the fluid .
i just use dot 3 (new bottle), never had a problem before .
there is specific clutch fluid for some things , my street bike has it even though i just use dot 4 instead .
74 Fj40-350,sm420,60 series axles,36.5 swampers, aussie locked, saginaw.
11-06-09, 07:28 PM
#14 (permalink)
Cool, thanks.
