10-27-09, 06:47 PM
#31 (permalink)
photosynthesizing
Originally Posted by mmw68
Originally Posted by matt.mcinnes
All I can say is MY INSPIRATION
Top work Pappy
Thanks Matt. While our engines are polar opposites, it does show what the 3FE is capable of. Long live the mighty 3FE.
aka Bushrat
1969 FJ40 Project TOROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC, 4WDB ... assembled!
1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage.
"EFI Jon, EFI." - Juane
10-28-09, 10:24 AM
#32 (permalink)
What an awesome writeup...
Toyota Land Cruiser...It's the only way I roll.
1998 UZJ100...1967 FJ40...1964 FJ45 SWB
11-06-09, 09:21 AM
#33 (permalink)
whoa!
Great ROTM
That engine is beautiful!!!!
Great job, and thanks for sharing
1981 FJ 40
1989 FJ62
11-07-09, 06:41 PM
#34 (permalink)
i am ...
inspired. Very nice work.
thanks, fj hunter
wife (OEM), 1 dog, no cats, 4 married kids, 1 split, so 10 kids, three grandkids.
fj40-1/69 DD
frame/body orignal, eng/running are fj40-74. SF rear, FF front. warn locking hubs. ARB Lockers front/rear. On-board air (ARB).
6" lift, SUA/SPRUNG, Offenhauser 4 barrel manifold/Edlebrock 650 cfm carb, 315 75R/16's, 8274-50 Warn, f engine
Completely rewired/Digital lamps/original headlights.
fj40-10/72, 6 in lift, front disc brakes, no engine, no tranny, sprung, needs assembly.
11-08-09, 09:23 PM
#35 (permalink)
Originally Posted by pappy
Suspension, Steering, and Brakes
Steering box is from an FJ60, and frankly, if I did this over again I would have gone Saginaw. Oh well.
Have you thought about running the 3FE steering pump?
Tranny and Transer Case
Even with 4.11 in the axles, 35" tires, and fifth gear the rpms are higher than they need to be. Cruising at 70mph the engine is spinning 2700rpm and it really doesn't need to.
I am surprised at this. How are you monitoring your speed? My 40 w/ 4.11's turns 3k to run 69 MPH. This is w/ 33's and no 5th gear or underdrive in the case...
Fuel Delivery
From the fuel pump the line runs into a 5/16" hard line on the frame to the front. The filter is mounted to the side of the charcoal canister and the flex line from the frame to the filter is from an FZJ80 (90923-01396). The same hose used on FJ62s and mini-trucks was stupid money, but the FZJ80 hose was significantly less expensive (thanks to CruiserDan for helping me "cobble" this together), and it fit the application perfect. From the filter the FJ62 hose was use up to the engine. The hard line that usually runs behind the cylinder head on FJ62s did not clear the FJ40 firewall and needed to be bent up to clear. The fuel return line is 1/4" hard line that runs along the frame to the tank.
What fuel filter are you using? I take it the early '80's Cressida pump can put out enough volume and pressure for the 2FE?
Engine
I just came back from a trip to Moab, UT and the engine worked flawless. Plenty of torque on the rocks. The freeway drive out was very pleasant. The engine was smooth, and I easily cruised at 70mph with throttle to spare. Passing trucks at 80mph was no problem, except the fear factor of driving a tall, short wheel base truck with a twitchy rear locker that fast. Once this truck is in 5th gear it stays there.
Emissions
This truck has been de-smogged. The EGR and the smog pump are gone. The EGR holes in the intake plenum and the exhaust manifold were plugged using expansion plugs. The smog pump, which normally is the idler for the water pump, was replaced with a home built idler using a FJ62 power steering idler pulley. I did retain the charcoal canister, the PCV, and I did install a catalitic converter.
Awesome - I love it!!! What CAT did you go with?
11-09-09, 08:27 AM
#36 (permalink)
photosynthesizing
No, the 3FE pump is located on the passanger side where the 2F alternator mounts. It was easiest to keep the 2F accessories because they bolted directly to the 2F.
I have an electric speedometer so I know my speed is correct.
I run the OEM 3FE filter. As far as I've been able to find out all Toyota EFI have the same fuel pressure requirements. This pump was used on 22RE, and 5M-GE engines.
Thanks. No idea on the cat. What ever the muffler shop installed.
aka Bushrat
