Originally Posted by Sloan
How do I check for that?
There's a low $$$ device sold at auto stores that will tell you if you have combustion gasses forcing their way into the coolant jacket. Kind of a squeeze bottle with a sponge on the end and filled with a fluid that will change color if combustion gasses are present (or something like that IIRC). You fit the bottle to the radiator fill spout and give it a squeeze. If you problem is bad enough you'll see air bubbles in the radiator fluid. Just remove the cap, start the engine, and keep an eye on the fluid as the truck warm up. The fact that you have the same gunk in both the radiator and the exhaust says that fluids, etc, are migrating around. You'll probably hydraulic a cylinder upon starting pretty soon if you don't solve the issue.
