In my haynes manual, it show a pre 72 wiring diagram w/ 7 wires going to the cluster. The cluster appears to have an ammeter, fuel gauge, oil pressure warning light, high beam indicator, and water temp gauge. In the 73 picture, I see 6 wires going to the cluster, all are the same except I don't see any high beam indicator...anywhere. So maybee it's in the 73 cluster too, not sure, I drive a 55. If the newer cluster also has a high beam indicator in it, it should bolt right up, as it were. You may need a different sender for the oil guage, not sure.
