Old 07-08-09, 09:36 PM   #1 (permalink)
cruisernerd's Avatar
pto + newb = dumb question
hi,
i have a question about the pto winch.
do you shift into N in the t-case to engage the winch? or can the use it while the truck is in gear?
i'm interested in finding one, but am only asking out of curiousity. and i have no experience with them.
thanks,
michael vick is a loser.
cruisernerd is offline   Reply With Quote
Old 07-08-09, 10:04 PM   #2 (permalink)
That 25 Guy.
Cruiser_Nerd's Avatar
TLCA# 12092
Not a dumb question for someone who hasn't seen one. Most Cruiser PTO's are driven off the ouput shaft of the transmission so there are multiple speeds available.
You can put the transfer case in neutral or you can engage the PTO as well as any gear at the same time to assist with the driven wheels. I've never had occasion to do that, I'm sure others have, no idea if it's recommended or not. There's a set of operating instructions kicking around here somewhere.
Jim
FJ25.com
"The FJ25 is almost humorous in its simplicity, but therein lies its beauty." Nina Padgett - Autoweek
Cruiser_Nerd is offline   Reply With Quote
Old 07-08-09, 10:21 PM   #3 (permalink)
orangefj45's Avatar
cruisernerd meet cruiser-nerd!
TLCA and PMC member
looking for Advance Adapters or marlin crawler parts? send me a pm!
bill dorry style ps brackets for sale:
http://forum.ih8mud.com/merchandise-...ml#post4481037
orangefj45 is offline   Reply With Quote
Old 07-08-09, 11:20 PM   #4 (permalink)
lostmarbles's Avatar
I have always been too scared to put my transfer into anything other than "neutral" for winching - because I know my rope needs to be kept taut in order to get wound onto my drum neatly/properly.
Loose rope + inward-winding-winchdrum = jam-ups, tangles, damaged rope, and worse (ie - breakages).
(And even winching with the rope kept taut - I still succeed in getting things "messed up" occasionally - Usually when the situation forces me to choose an anchor point that's off to one side where the rope builds up on itself (on that same side) rather than being wound evenly across the whole width of the drum.)
PS. --- But it sure looks cool when I see people spinning their wheels while winching. (However it's just another pleasure I can't afford. )
Name's really Tom & I have a 1979 Australian-market BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A tire is really a tyre...........
lostmarbles is offline   Reply With Quote
Old 07-09-09, 12:24 AM   #5 (permalink)
HelimanBD's Avatar
cruisernerd,
I will shift to,
>>> "N" and use 1st/2nd/3rd/4th gear while trying to recover
another stuck off roader when acting as an achor point.
Also this mode for tensioning the cables just before self
recovery.
>>> "4L" once cables tensioned. Use 1st/2nd/3rd/4th gears
(your pref) and the 4 wheels will turn, lessening the
strain on both PTO and cables. If you are really bog
down, tire spins, PTO try to retrieve BUT will eventually
breaks the safety pin. You will then need to replace the
safety pin and use a pulley/snatch block to further lessen
the load on cables and PTO......
>>> in all cases, the use of pulley/snatch block is recommended.
regards,
HelimanBD.
Originally Posted by cruisernerd View Post
hi,
thanks,
1989 LJ70 2L + Turbo - 32x11.5x15 - Front & Rear lockers - PTO, front ROCKY alloy & 10mm cable- custom snorkel - OBA ....
1981 BJ40 Stock/Standard- B 3L Diesel - 33x10.5x15 - Toyota PTO ..... total rebuild from scrap...
HelimanBD is offline   Reply With Quote
Old 07-09-09, 06:52 AM   #6 (permalink)
shelfboy1's Avatar
TLCA# none
there may be times when your stuck bad and you need the wheels to assit.i have always used 4lo 1st gear with the winch and no problems after only 30 or so years good luck.
64,65,69,69,70,73,77 fj40s wagon and pickup sold
shelfboy1 is offline   Reply With Quote
