Old 07-13-09, 10:22 AM   #31 (permalink)
Pin_Head's Avatar
Originally Posted by e rock View Post
You can't properly adjust the shoes without the master cylinder installed. .
No, not really. You can adjust them properly w/o having a master installed, but what's the point? You want to drive it.
Pin_Head is offline   Reply With Quote
Old 07-13-09, 09:22 PM   #32 (permalink)
No Brain No Headache
rockcod's Avatar
TLCA# 3236
Originally Posted by Pin_Head View Post
That is a lot of work and expense compared to adjusting your brakes, isn't it?
Well Charlie, it is a Cruiser after all, so yeah it is expensive, but well worth it to me
Tony
click links below
"Snotz" 63 FJ40
"Red Truck" 65 FJ45 SWB
"Sully" 72 FJ40
rockcod is offline   Reply With Quote
Old 07-13-09, 10:40 PM   #33 (permalink)
If your drums are not completely round, you will get drag and even a blocked wheel without proper adjustment. When the wheel turns out of the protruding part, the brake pad will have a lot of free play. After every adjustment, move the wheel at least half a turn so you make sure you are not adjusting the pad against a flat part of the drum. Spongy pedal is air, pumping pedal in a non booster system is caused by incorrect pad adjustment. You can isolate the problem by clamping the rubber part of the brake line with a vise. If the pedal goes up when you clamp the rear, there you have it.
68 FJ40
FJ70 Disk Brakes
Aftermarket Electric Fan
Power Steering
NEW: 1FZ-F engine and Series 70 Gearbox
jtoro is offline   Reply With Quote
Old 07-14-09, 06:49 PM   #34 (permalink)
dmaddox's Avatar
TLCA# 13877
I went out to the junkyard and purchased yet another MC out of a 84 minitruck.
Believe it or not, I now have pressure. How or why, I don't know. All I can say is that the previous M/C's were either A) not bled well enough or B) bad
Thanks everyone for all of the help on this rather strange issue - Dallas
1996 -80
1977 -40
1963 -45
dmaddox is offline   Reply With Quote
