Old 07-04-09, 11:39 PM   #1 (permalink)
Bad Mojo's Avatar
Braking Turns On Signals
Lately whenever I break my blinker lights on the instrument panel come on dimly. Is this normal or do I have something else going on? Thanks
1977 FJ40 - 2.5" OME on 33" Skinnes Adding: FJ60 PS
J.E.E.P - Joke Even Enhanced Properly
Bad Mojo is offline   Reply With Quote
Old 07-05-09, 06:49 AM   #2 (permalink)
dargreg's Avatar
TLCA# 4179319
GROUNDS
dargreg is offline   Reply With Quote
Old 07-05-09, 07:38 AM   #3 (permalink)
Coolerman's Avatar
TLCA# 13645
Search for turn signal ground for detailed info on what you need to do. Short story. Pull the front turn signal housings apart, clean all the bulb sockets, either add a ground wire to the bulb housing or clean the contact between the housing and the fender. Repeat for the rear. Later rear housings had a separate ground wire that can loose it's connection.
!Oy my 1971 FJ40
It's not having what you want, it's wanting what you got...
http://tinyurl.com/ygeqfp7 FJ40 Wiring Parts for Sale
http://tinyurl.com/mxj5ve Misc Parts FOR SALE!
http://tinyurl.com/47zpb (My Web Site)
http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet)
Coolerman is offline   Reply With Quote
Old 07-05-09, 08:01 AM   #4 (permalink)
Bad Mojo's Avatar
Thanks guys. I will give that a try later today, hopefully that works.
Old 07-05-09, 10:31 AM   #5 (permalink)
Pin_Head's Avatar
It is a floating ground problem and since it is a 77, where the brake and turn bulbs are separate, you can also tell that one or more of the rear lamp housings has a bad ground connection to the bumper. If you look carefully, you should also see the running lights come on at the same time.
Pin_Head is offline   Reply With Quote
