Old 07-03-09, 10:33 PM   #1 (permalink)
TLCA# 18958
New 700R4 wont shift into overdrive
Installed a new (rebuilt) 700R4) with the Painless wiring solenoid kit. It wont shift into 4th gear. Any ideas?
Thanks,
Flash
Flash1034 is offline   Reply With Quote
Old 07-04-09, 12:51 AM   #2 (permalink)
dargreg's Avatar
TLCA# 4179319
Has it got shift kit , Is the detent going into forth ,do you have a kick down installed ,did you put at least 400 gals of oil in it ( converter takes a lot) , Is it wired right.All these or any one of these will give you this symptom. If the kick down is not adjusted correctly say goodbye to your rebuild if you,ve put many miles on it.
dargreg is offline   Reply With Quote
Old 07-04-09, 09:10 AM   #3 (permalink)
orangefj45's Avatar
is the 4th gear pressue switch installed and wired correctly?
i would call the transmissions shop who rebuilt it and go from there.
georg @ valley hybrids
TLCA and PMC member
looking for Advance Adapters or marlin crawler parts? send me a pm!
bill dorry style ps brackets for sale:
http://forum.ih8mud.com/merchandise-...ml#post4481037
orangefj45 is offline   Reply With Quote
Old 07-04-09, 10:27 AM   #4 (permalink)
Cirbo's Avatar
Did it come from TCI?
Certified JB-Welder
build thread
Cirbo is offline   Reply With Quote
Old 07-04-09, 10:31 AM   #5 (permalink)
TLCA# 18958
Nope. an independant trans shop. Lasted 60 miles. Going back on Monday I guess. I have a small vacuum activated switch which is supposed to tell the trans to shift to 4th. I drove it this morning and it now wont shift out of 1st. What the he** is going on?
Flash
Old 07-04-09, 10:35 AM   #6 (permalink)
orangefj45's Avatar
the vacuum switch controls lockup, not overdrive.
if it's not shifting out of first, then i'd have to assume that the throttle valve is stuck. that's usually due to contamination hanging up the valve as the clearance in there is very tight and needs to be.
pop the hood, push down firmly on the exposed portion of the tv cable and then let it snap back into place. do this a couple of times. hopefully that'll free up the valve enough to get it to work for a little while, at least long enough to get it back to the shop. call them, they might want to get it towed back to them to prevent any other possible damage by driving it that far.......
hth
TLCA and PMC member
Old 07-04-09, 06:11 PM   #7 (permalink)
shelfboy1's Avatar
TLCA# none
if the tv wire is not adjusted right the tranny pressure will be way out of wack and could ruin the tranny.good luck
64,65,69,69,70,73,77 fj40s wagon and pickup sold
shelfboy1 is offline   Reply With Quote
Old 07-05-09, 01:16 AM   #8 (permalink)
TLCA# 18958
What and where is the "tv wire?" Sorry guys, I dont know much about automatics.
Flash
Old 07-05-09, 04:08 AM   #9 (permalink)
shelfboy1's Avatar
TLCA# none
tv cable is on right side of tranny and hooks to carb and adjusts pressure as throttle increases .also od is electric there is a plug on the left side of tranny for the od plus you need some other parts to make it work.we run 700r4s in our mud trucks but dont use overdrive.google gm 700r4 and you should be able to learn everything good luck
Old 07-05-09, 10:24 AM   #10 (permalink)
orangefj45's Avatar
not quite.
the plug on the driver side of the transmission case right behind the shift linkage is for torque converter lockup and has absolutely nothing to do with overdrive.
overdrive is a 4th gear in the transmission. lockup is a function of the torque converter.
the tv cable runs from the throttle body or carb ( right below the throttle cable ) to the passenger side of the trans, close to where the dip stick tube goes thru the case.
TLCA and PMC member
Old 07-05-09, 10:46 AM   #11 (permalink)
TLCA# 18958
Thanks guys. I'm on my way out to check it.
Flash
Old 07-05-09, 02:11 PM   #12 (permalink)
TLCA# 18958
Ok. The tv cable is taught and seems to move freely with the throttle. Any other ideas
Thanks,
flash
Old 07-05-09, 02:47 PM   #13 (permalink)
dargreg's Avatar
TLCA# 4179319
You have to hold the throttle wide open and adjust the tv cable from there ,usually by depressing a button on the cable which will alows the tv cable to become in sink with the throttle cable.
