| Rocman, an email was sent from FJ40Jim to the rgarza67 address on Jun.29th.
The fuel pumps have 2 failure modes. A cracked diaphragm is the obvious one, because the pump will leak fuel rather than pump.
The other failure is the valve discs get scratched from passing dirty fuel and they will no longer make a good enough seal to move fuel. The only way to know for sure if this is a problem is to pull vacuum on the valves and see if they will hold vacuum for several seconds.
But if the pump arm is moved and fuel is not pumped, the pump is bad, regardless of root cause.
__________________ Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's  since 1988. |
