| Some quick basic checks you can do to see where the problem lies.
Disconnect the wire that goes to the sender and connect it to ground. Now turn on the ignition. If the wire to the sender is intact, and the gauge is working then the needle will swing to the Full mark. If that's the case, then the problem is in the sender/ ground wire.
If you have a multimeter, check that the sender body is grounded by measuring the impeadence between the sender body and any handy chassis/body point. i.e. seat mount bolt. The impeadence should be very low, under 1 ohm.
If you have an open circuit, then the ground wire is not attached to a ground point, could be faulty or missing.
The fuel sender has a total impeadence (resistance) of 120 ohms +/- 6.5 ohms when the tank is empty, and 17 ohms +/- 2.1 ohms when full. It should have something like 40 ohms +/- 4.5 when the tank is half full. If you don't get any measurement with your multimeter then the sender is faulty.
See how you go with that lot.
Cheers
Perry
__________________ A man generally has two reasons for doing a thing
one that sounds good
and a real one.. UNDERSTEER is when you hit the wall forwards. OVERSTEER is when you hit the wall backwards. HORSEPOWER is how fast you hit the wall. TORQUE is how far the wall moves after you hit it. |
