06-29-09, 11:28 AM
| | Forum Regular
| Oil pan leaking, what to do? The oil pan for my 78 seems to leak oil between the pan and skid plate. I have the pan off and it looks like it is seeping out under the plate, should I:
1. Try to fix it?
2. Put it back on the way it is because it is barley leaking at all?
3. Buy a new one, How much do they run and where would I get the best deal?
__________________ 83 FJ40 p/s a/c all original
78 FJ40 project |
06-29-09, 11:36 AM
| | ih8mud optimist
| Absolutely no doubt fix it now! .....they have a way of asking for love and if you refuse they'll shout louder....ie - break worse...... |
06-29-09, 11:41 AM
| | Forum Lifer
| Most of the time one of the spot welds have a small crack around the edges..... can be easily brazed-welded from the inside....... or you can coat the inside with fuel tank sealer........ Gas Tank Sealer - Better than Kreem - KBS Coatings
__________________ |^^^^^^^^^^^^^^^\ ||__ |.......PBR BEER TRUCK.... ||""\_____\ |_____________________/||__|___| |(@)(@)"""""""""""|(@)(@)*****|(@) The Beer Truck, that ran over Bunny..... (\__/) (='.'=)  (")_(") |
06-29-09, 11:47 AM
| | GIGGIDY!!!
| Often rust will occur in that spot. If you pull it and clean it up you could have worse leaks then.
I would pull it and clean it with a pressure washer real well - then look for cracks and leaks.
I would recommend replacing it with a good used one - I've got one if you need it off of a 76. |
06-29-09, 12:39 PM
| | Forum Regular
| Quote:
Originally Posted by eventhough Often rust will occur in that spot. If you pull it and clean it up you could have worse leaks then.
I would recommend replacing it with a good used one - I've got one if you need it off of a 76. | How much for the used one?
I saw the one on e-bay, do you think that is the correct pan for a 78? were they all the same?
78 FJ40 project |
06-29-09, 12:56 PM
| | GIGGIDY!!!
| PM sent |
06-29-09, 03:22 PM
| | Site Addict
| allll the same just went through this same thing - the only difference is ripples on the outside of the pan and a different size plug.
that ebay add is cheap if the price doesn't shoot up... Oil Pan ~$200 at CCOT
i wonder how much Cdan would charge
__________________ 78' FJ40 "finished" - body '77 converted to '78, '78 engine, '78 wiring harness and switches, 4 wheel disk, '68 bib, Ehsan Khaki Soft Top, half doors with khaki uppers, rear half doors with khaki uppers - build thread: http://forum.ih8mud.com/40-55-series...-77-build.html
'09 Nissan Versa 6-Speed 1.8L |
06-29-09, 04:05 PM
| | Forum Regular
| Quote:
Originally Posted by AATLAS1X | I will also vouch for the Toyota F.I.P.G. gasket sealer. I did exactly what Shane mentioned above. It was the only way I was able to stop my oil pan leak completely. |
06-29-09, 05:01 PM
#10 (permalink)
| | Forum Regular
| Quote:
Originally Posted by HKforte I will also vouch for the Toyota F.I.P.G. gasket sealer. I did exactly what Shane mentioned above. It was the only way I was able to stop my oil pan leak completely. | Where do you put it? on the gasket? or around the skid plate?
What does F.I.P.G. stand for?
78 FJ40 project |
06-29-09, 05:04 PM
#11 (permalink)
| | Forum Regular
| Quote:
Originally Posted by antFJ allll the same just went through this same thing - the only difference is ripples on the outside of the pan and a different size plug.
i wonder how much Cdan would charge | I thought it looked the same but was not sure, the part number is on it but I don't know what part # I need.
I can never get ahold of Cdan.
78 FJ40 project |
06-29-09, 05:36 PM
#12 (permalink)
| | Supporting Vendor
| Quote:
Originally Posted by 85fr16 Where do you put it? | Thin skin on both sides of the gasket. Quote:
Originally Posted by 85fr16 What does F.I.P.G. stand for? | Fawking ImPenetrable Glue as the techs call it.
It's not cheap, but it is the BEST!
06-29-09, 05:48 PM
#13 (permalink)
| | Site Addict
| Quote:
It's not cheap, but it is the BEST! |  .....form in place gasket (FIPG). It is a gasket sealant that comes in a tube or a container. I have used both the Toyota fipg and off brands, they seem to be the same crap. Only one of the three auto parts stores in my area carries FIPG on their shelf. As I recall it was about half the price of the OE stuff. You might have to call around if looking for an off brand. |
06-29-09, 06:00 PM
#14 (permalink)
| | Forum Regular
| Quote:
Originally Posted by vtcruiser60  .....form in place gasket (FIPG). It is a gasket sealant that comes in a tube or a container. I have used both the Toyota fipg and off brands, they seem to be the same ****. Only one of the three auto parts stores in my area carries FIPG on their shelf. As I recall it was about half the price of the OE stuff. You might have to call around if looking for an off brand. | What about permatex ultra copper? I have always had good luck with that.
78 FJ40 project |
06-29-09, 06:59 PM
#15 (permalink)
| | 250+ Club
| Quote:
Originally Posted by 85fr16 What about permatex ultra copper? I have always had good luck with that. | The copper stuff is great for intake and exhaust stuff but for the oil pan you want the black stuff. I've been using ultra black with extra oil resistance and it seems to work well. If you can get your pan off an actually get it clean and free of paint, rust flakes, and oil some JB weld will likely fix it up fine. I cut the edges of the plate off mine to weld the pan up, then I JB welded it over all the seams and it holds fine. A new pan is in my future eventually, but I have to recover from my engine rebuild costs for a while. Mine isn't pretty, but it works.
__________________ 79 FJ40,85 Mustang GT,05 Tacoma,00 4Runner,89 pickup |
06-29-09, 07:38 PM
#16 (permalink)
| | Site Addict
| Questions about oil pan gasket installations and proper sealants do pop up from time to time. Check the FAQ's posted by POSER, in particular the following helpful thread.... Oil pan/ side cover gasket stuff....(FAQ) |
06-29-09, 07:51 PM
#17 (permalink)
| | 250+ Club
| buy one put it on and quit being so cheap fix it right and be done with it
__________________ kool ken |
06-30-09, 06:31 PM
#18 (permalink)
| | Forum Regular
| Quote:
Originally Posted by fieldsken1 buy one put it on and quit being so cheap fix it right and be done with it | You sound like my wife.
78 FJ40 project |
06-30-09, 08:01 PM
#19 (permalink)
| | Forum Regular
| my 71 was leaking from spot welds inside the pan ,i hot pressure washed it, then welded it and put a dab of j-b weld on top of the welds. no leaks so far .  |
