Old 06-25-09, 05:22 PM   #1 (permalink)
Zang469's Avatar
Starting problem ?? sometimes.
73 fj40. The problem has only happened a couple times and fixed itself once without me trying anything. When I turn the key forward to the starting position the amp gauge moves but the starter does'nt turn over. I did the old trick of crossing the celinoid with a screwdriver and it cranks over fine. So were do I start ?? Do the ignitions go bad ? Thanks in advance, Z
Zang469 is offline   Reply With Quote
Old 06-25-09, 06:27 PM   #2 (permalink)
antFJ's Avatar
starter solenoid? bad ground to starter? does it click or anything or does it do absolutely nothing when you turn the key to start?
Oct '76 FJ40 (used to be) used for parts
78' FJ40 in progress - body '77 converted to '78, '78 engine, '78 wiring harness and switches, 4 wheel disk, '68 bib, Ehsan Khaki Soft Top, half doors with khaki uppers, rear half doors with khaki uppers
'84 S-10 - '94 S-10 blazer leather interior, 3" hocky puck lift
antFJ is offline   Reply With Quote
Old 06-25-09, 08:06 PM   #3 (permalink)
Zang469's Avatar
When it won't start it makes no sound at all, just the amp gage draws down. Then the next time you try it it fires right up. I did check the ground wires and everything looked good. I can always push start it, lol.
Old 06-25-09, 08:10 PM   #4 (permalink)
450,000+ mile club
TLCA# 2231
sounds like starter solenoid is bad...had you tapped the top of the ss to see if it crank over then?
JohnnyC is online now   Reply With Quote
