06-21-09, 09:51 PM
| | Forum Regular
| Replacing a fuel pump on fj40 My mechanical fuel pump on my 78 fj went out and I was about to get ready to change it out. What I thought was going to be an hour or so looks like it is going to take alot longer then that. I was wondering if it would just be better to put an aftermarket electric fuel pump on it instead of the stock mechanical one. Does anyone have any thoughts on this? Thanks, RG |
06-21-09, 11:16 PM
| | Site Addict
| Our '79 FJ-40 had the mechanical pump replaced by a simple electric pump. Worked fine. I didn't even realize it until I took the truck apart, that's how well it worked.
Just wire it to switch on with the key, and you'll be good to go.
Dan |
06-22-09, 12:01 AM
| | 250+ Club
| The mechanical pumps last a very long time. I would replace it with an OEM. Good for another 30 years.
Should be a fairly easy process. I think it's two bolts and a pair of fuel lines and you are done.
__________________ 1978 FJ40 |
06-22-09, 05:19 AM
| | GIGGIDY!!!
| Quote:
Originally Posted by Robert LaDuke The mechanical pumps last a very long time. I would replace it with an OEM. Good for another 30 years.
Should be a fairly easy process. I think it's two bolts and a pair of fuel lines and you are done. | x2
What is taking so long with the replacement? |
06-22-09, 05:44 AM
| | Site Addict
| unless you buy a good electric pump forget it .oem is best and its a half hour job to change for most people .unhook 2 fuel lines maybey 3 remove 2 bolts ,clean gasket surface and replace.i think your making this more diffucult than it needs to be .how long will it take to cut lines run wires and mount the electric pump right. your choice good luck
__________________ 64,65,69,69,70,73,77 fj40s wagon and pickup sold |
06-22-09, 08:05 AM
| | Site Addict
| On a 78 there should be two lines, one rubber one hard.
Undo two bolts pull it out. Not much to it.
Buy a new gasket for it as well.
The 78 pump is rebuildable and can be torn down and rebuilt if needed.
Dave
__________________ "The time has come" the Walrus said," To talk of many things.."
In the Trees.... OH
80 fj40, 2.5 OME Dakaar springs, 33" bfgs. "Charlie Brown"
88 fj62 Bone stock, Daily Driver, Bone stock. "Moby" |
06-22-09, 08:13 AM
| | Site Addict
| Quote:
Should be a fairly easy process. I think it's two bolts and a pair of fuel lines and you are done. | X 3
Plus, if it takes you longer than an hour to replace the mechanical fuel pump, it'll take you even longer to remove it, mount the block-off plate, mount an electric pump, and figure out how to plumb it. Quote:
Originally Posted by DanS HJ-45 Our '79 FJ-40 had the mechanical pump replaced by a simple electric pump. Worked fine. I didn't even realize it until I took the truck apart, that's how well it worked.
Dan | Not so much. That'll work, but there's a safety issue -- you don't want the pump fire-hosing fuel all over the place after you wreck and sever the line to the carb. Most EFI set-ups have a circuit that shuts off the fuel pump when it detects no ignition events. |
06-22-09, 10:01 AM
| | Forum Regular
| Quote:
Dan | I'd opt for the 1 hr. stock replacement option.
Most electric fuel pumps are designed to push fuel so you'd want to mount the pump on the frame rail back near the tank. Wire in a manual safety shut-off switch in the cab as well. Use something big and easy to hit when you're upside down. Quote:
Originally Posted by PHAEDRUS The 78 pump is rebuildable and can be torn down and rebuilt if needed.
Dave | Where? Where? Where? I recently had to replace my fuel pump because I couldn't find a rebuild kit. |
06-22-09, 12:09 PM
| | Forum Regular
| Just replaced my Fuel pump Yesterday went out to shop for one all i got is a 3F fuel pump so i got it plugged right in and Now it works perfectly 2 bolts and some hoses and your done
__________________ 1982 FJ40-Metal Gear Edition (off roader)
2005 Chevrolet SSR 6.0L (once in 2 weeks)
2004 Chevrolet silverado RST (once a Week)
2008 Mercedes benz SLK 350 (Nightly Driver)
2009 Caprice SS 6.0L (Daily Driver)
2005 Lexus LS430 (daily Driver)  Sold |
06-22-09, 12:17 PM
#10 (permalink)
| | Forum Lifer
| Replace with mech.Toy. should take less than 1 hour. Mike
__________________ Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80 |
06-22-09, 12:19 PM
#11 (permalink)
| | Forum Regular
| definitely under hour of work
06-22-09, 09:43 PM
#12 (permalink)
| | Forum Regular
| I will look at it again. I know the 2 bolts are all that hold the pump on but it was the other stuff like the battery box that looked like it was in the way. I will look again and check if I just saw it wrong. |
06-22-09, 11:21 PM
#13 (permalink)
| | 250+ Club
| If I recall correctly , I think I found the pump is easiest to get at from bellow.
