Old 06-19-09, 03:34 PM   #1 (permalink)
alabamacruiser7's Avatar
TLCA# 19796
FJ40 Transfer Case will not go into 2wd
I Just bought the 78 FJ40 in the for sale section. I was trying to tow it home so I put the transmission in neutral and wanted to put the transfer case in neutral aswell. The transfer case seems to be in 4H and will go to neutral but will not go to 4l or 2H. Any sugestions?
2003 Xterra
1978 FJ40 31 BFG AT's and a bikini top for now.
My slow go build thread: http://forum.ih8mud.com/40-55-series...ml#post4731342
alabamacruiser7 is offline   Reply With Quote
Old 06-19-09, 03:42 PM   #2 (permalink)
MtnClimber's Avatar
Try rocking the truck while the hubs are locked. That movement usually helps me when shifting the T-case. Mine is pretty stiff as well, so I have to bang my fist on it to move the case shifter.
White male seeks beautiful FJ. Must have good body, must love the outdoors and like mountain climbing. Must be willing to go topless any where we go. Must be eager to get down and dirty for long periods of time and be low maintenance.
http://i82.photobucket.com/albums/j2...oosted/fj1.jpg
MtnClimber is offline   Reply With Quote
Old 06-19-09, 04:11 PM   #3 (permalink)
TLCA# 19796
I tryed that and it has automatic locking hubs covered by hubcaps. I thought that was weird.
2003 Xterra
Old 06-19-09, 04:26 PM   #4 (permalink)
JasonH's Avatar
TLCA# 8123
You've probably still got the original drive plates in there.
Back up about 10 feet or so, occasionally trying to push it into 2hi. It's just bound up.
Jason Harsch
Lone Star Land Cruisers DFW Prez
WTotEC
79 FJ40 The Smurf
"He's got a blue Toyota, like I always wanted." - Lyle Lovett
JasonH is offline   Reply With Quote
Old 06-19-09, 08:10 PM   #5 (permalink)
KOOTENAY KRUZER's Avatar
TLCA# 17298
I find that to go from 4H to 2H the easiest method is to accelerate gently then back off the throttle while pushing forward on the lever. You may need at least one tire on something loose like gravel. I do not have any luck trying that shift while the vehicle is sitting still.
Wayne
1983 BJ42, SOA, Shackle Reversal, 4.11 diffs, locker in rear, Saginaw power steering, 33x12.5s. 4-wheel discs
1979 BJ40, 3"lift, 1982 BJ42 drivetrain, Saginaw ps, 32x10.5s, Warn 8274 winch
2001 Echo, stock
KOOTENAY KRUZER is offline   Reply With Quote
Old 06-19-09, 08:50 PM   #6 (permalink)
Shift collar backwards inside the nosecone possibly?
avgas is offline   Reply With Quote
Old 06-20-09, 08:05 AM   #7 (permalink)
couyld be the pivot point froze up, when was the last time it ran??
You could also just pull the driveshafts from the differentials, leave the slip joint on the transfer case.
That's usally what I do. Also if it hasn't run in a while good idea to make sure there is oil in the diffs.
those that fail to prepare are preparing to fail....Benjamin Franklin
1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains
1965/67 FJ45 SWB combining 2 into 1 under construction
1970 FJ55 all stock
1980 FJ40 all stock, factory air and power steering, 82,000 miles
3_puppies is offline   Reply With Quote
Old 06-20-09, 08:56 AM   #8 (permalink)
meh, eh!
steverb's Avatar
TLCA# 19573
go under and smack the linkage on the t case its probably a little rusted from rain and dirt and not being used.
http://www.4wheeling.ca
steverb is offline   Reply With Quote
Old 06-20-09, 10:48 AM   #9 (permalink)
If I go into 4Hi I cannot go into 2hi unless I unlock the hubs, then reverse 2 feet (I think it releases tension in the old case) and then I can smoothly shift upward to 2Hi. I've had my rig for years and it's always been like this
1977 FJ40 - Rebuilt 2F, New Steering, OME, Rear ARB, Rebuilt Rear-End, Electronic Ignition, Some Tires and a Wind-Up Clock From a Russian Tank
77cruiser77 is offline   Reply With Quote
Old 06-20-09, 08:25 PM   #10 (permalink)
TLCA# 19796
I went out today and tryed the reverse thing for about 30 minutes and it didn't work. It will shift from 4h to neutral but nothing else yet. And I don't have manual hubs.
Does anyone know why I wouldn't have manual hubs? Special edition or something?
I am starting to think that my transfer case and hubs are bad and I will just have to drive around in 4h.
2003 Xterra
Old 06-20-09, 10:43 PM   #11 (permalink)
Slow Lane Or No Lane!!
fj404life's Avatar
I would pull the auto hubs...and prolly put them on the shelf. But maybe try cleaning them up? Manual hubs...mo betta!
1969 FJ40 4" lift stock otherwise.
1973 FJ55 overdrive, weber, headers
www.oregoncruisers.com
fj404life is offline   Reply With Quote
Old 06-20-09, 11:24 PM   #12 (permalink)
amaurer's Avatar
What makes you think you have auto hubs?
Its likely that you just have drive plates, e.g. no disconnect at all.
1982 BJ42 "Krull" - DD
www.cruiseruser.com - Replacement gauges and custom knobs.
Have you met LonelyBot?
amaurer is offline   Reply With Quote
Old 06-21-09, 12:19 AM   #13 (permalink)
TLCA# 17298
x2 - they came from the factory with drive plates. The hubs were a dealer-installed option.
All 3 of my ?j40s have been easy to shift from 4h to 2h while the vehicle is moving, and usually impossible when the vehicle is stopped.
Wayne
2001 Echo, stock
Old 06-21-09, 03:00 PM   #14 (permalink)
TLCA# 19796
I didn't know about the drive flanges, that must be what I have. I have tryed to move the stick while the truck is moving. This is my first FJ40. I know in my old Jeep CJ that you are supposed to stay off the dry street in 4h or 4l and I also know that these landcruiser's are a ton better than jeeps so is it ok to be driving around in 4h. I guess the PO was doing that for a while because it is stuck there now. Or maybe somehow the 4 wheel drive is messed up and it is actually only turning the rear wheels.
By the way thanks for all the reply's, this website is great.
2003 Xterra
Old 06-21-09, 03:30 PM   #15 (permalink)
amaurer's Avatar
Whoa whoa whoa... I'm not disagreeing with you that FJ40s are better than jeeps, but you can't drive ANYTHING* around on the street in 4HI. Do not drive on the street in 4HI, even in your cruiser.
*exception - I've seen some vehicles with viscous couplers and full time 4wd call that setting "4HI". Generally thats called fulltime 4wd or AWD, however. I don't think there is a real standard.
Old 06-21-09, 08:39 PM   #16 (permalink)
wonder if the plunger mechanism is all corroded up on the nose cone??
or once again the pivot on the main shifter lever being froze up.
Any idea from the PO when the last time is was in 2H?
1970 FJ55 all stock
Old 06-22-09, 01:41 PM   #17 (permalink)
TLCA# 19796
Update: I changed the gear lube in the front end, trans. and transfer case today. It will still not come out of 4h, but I went to a gravel road with a buddy and popped the clutch and he said only the rear tires slipped. So the front tires are not engaging which means what? The flanges are broken or the transfer case is. I am in 4h but only the rear end is pulling.
I am not sure when the last time it was in 2h.
2003 Xterra
Old 06-23-09, 10:06 PM   #18 (permalink)
TLCA# 17298
Looks like you are actually in 2wd, check your likages to see if something is missassembled or stuck.
Wayne
2001 Echo, stock
Old 06-24-09, 06:11 AM   #19 (permalink)
TLCA# 19796
I have no idea how to go about that. I will have to do a search on here and see. I really think it is a bad transfer case because it will not move to any of the other gears. Or it might be both.
2003 Xterra
Old 06-24-09, 10:21 AM   #20 (permalink)
Pull the nose cone off the transfer case, I still think your shift collar is on backwards. There isn't a whole lot of moving parts in those transfer cases that can go "bad" maybe worn if something was "bad" in the transfer case you'd have alot of other symptoms. and the only thing that controls and engages your front wheel drive is the shift collar. Pull off the nose cone and learn something about your cruiser , then if it's the linkage or something else you can free that up as well
