Old 06-19-09, 10:54 AM   #1 (permalink)
Rookie
FJ40 Rocker Arm Oiling Problem?
Hi Guys and Gals. I have a 1977 FJ40 and before I tear it apart, I wanted to ask a question. How much oil should be getting to the top end (Rocker Arms). I know in some vehicles, if you take off the oil filler cap with it running, you have a mess. Not so on my 2F motor or on my friends F motor. I am not saying it is dry in there, but there is not oil flying around with it running? Am I getting enough oil. The head was sent out in 97' to be hot tanked, new valeve seals and so on. I ran it for about 7000 miles before I put it in storage until a few weeks ago. It runs fine and the oil pressure is great. I use only toyota oil filters on it. There is not excessive valve noise. I might just be paranoid. Any advise?
mikejmartino is offline   Reply With Quote
Old 06-19-09, 11:03 AM   #2 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
Welcome.
It is not supposed to be that way on the F/2F
If you are getting oil dribbling out of the rocker arms, you are fine.
Old 06-20-09, 06:41 AM   #3 (permalink)
Rookie
Thanks. If that is the case, I think I am fine.
Old 06-20-09, 09:33 PM   #4 (permalink)
rchandler's Avatar
Friend had head done and the new head gasket did not have hole for oil passage to the rocker arms ... It fried the top end .
Don't know why gasket would not have had one
Royota
rchandler is offline   Reply With Quote
Old 06-20-09, 11:03 PM   #5 (permalink)
Poser's Avatar
TLCA# 1856
Garage
What engine?
Old 06-21-09, 06:38 AM   #6 (permalink)
rchandler's Avatar
73 Original motor
Royota
Old 06-21-09, 06:41 AM   #7 (permalink)
IDave's Avatar
TLCA# 13705
Probably put the head gasket on backwards.
Unless it's an early '73 and they just didn't hook up the oil pipe.
9/70 FJ40
9/64 FJ45 (L) P-B
4/84 Toy 4x4 Mini PU
We do not see things as they are;
We see things as we are. --Talmud
IDave is offline   Reply With Quote
Old 06-21-09, 07:21 AM   #8 (permalink)
I just had the valve cover off yesterday on my 78 2F and the oil just kind of seeps out of the rocker arm holes. No splashing at all.
--Eric
Eric_S is offline   Reply With Quote
Old 06-21-09, 07:34 AM   #9 (permalink)
rchandler's Avatar
It was long time ago but the gasket on backwards does ring a bell . Everthing lines up except the oil galley . Not 100% sure on the year
Royota
