Originally Posted by vt78cruiser
Does anyone make an adapter to go from a newer style split t-case to a stock '78 front driveshaft? I only say front as the rear has been adapted with a disc brake adapter kit.
I have not ever seen one.
You will either need to get the female part of the later model drive shaft and install it onto the male part of your older drive shaft, or, get the earlier model companion flange for the front output of the split transfer case and swap them.
