Coolerman
SILVER Star
- Joined
- Jan 5, 2004
- Threads
- 142
- Messages
- 6,739
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
OK I thought I would post some pics here of this procedure with the tool.
Fellow Bluegrass Cruiser member bought the special shim determining tool and invited me to help him do the procedure.
Pic 1: Install the scriber part of the tool inside the axle housing then mount the rod assembly including the spring arm attachment with the bearings installed.
Tighten the tool nuts until the spring scale reads 4.4-5.5 lbs.
Measure the distance between the flat spots on the tool spacers under each nut.(sorry did not get that pic refer to instructions in the FSM ) Write this down as measurement A.
Paint the tool shaft with red lead.
Pic 2: Reach in and pull the scribe forward until it touches the shaft. Use the spring attachment arm to rotate the shaft 360 degrees. You should have a nice scribed line in the red lead. Carefully remove the tool without disturbing the scribed line. Set aside.
Pic 3: Clean the flats on the top and bottom of the knuckle housing and measure the distance between them. Write this down as measurement B
