03-29-09, 06:37 PM
MECHANICAL vs. ELECTRIC FUEL PUMP on 2F
PRO's CON's on each for a 78 2-F FACTORY CARB What are your recomendations, if electric is used with type/brand have you used and did you use a fuel pressure regulator and set on what.. Or Should I stick with the stock mechanical? Lots of questions but really curious.
03-29-09, 06:56 PM
The stock mechanical pumps are great, they last forever and run the PSI that the OEM carbs need. Carry a spare if you are worried about shitting a pump on the trail
Alex
トヨタ ランドクルーザー
'76 Yella FJ40 短いバス
'94 FJZ80 Cummins 4BTA Conversion
'07 Tacoma, stock but locked
Ronaldus Magnus
It has been said that politics is the second oldest profession. I have learned that it bears a striking resemblance to the first.
03-29-09, 07:04 PM
Yhea I am running a Mechanical pump on mine, took it wheeling this weekend and ran flawless, my brothers mechanical crapped out earlier in the week, and we popped a mechanical one in to get him home, and decided to run it anyway, and after climbing the hill out it died, so i ran to the auto parts store and bought another to get him out of the hole popped it on and guess what it.. It got him home but also started acting up as well.. I'm curious just to see if anybody is running a electric with success. I plan on carrying an electric one in my survival pack just as a back up, but wanna make sure it will perform enough to get me home.
03-29-09, 07:08 PM
If you are having THAT many problems with a mech fuel pump thats telling me one of 2 things.
1. Your fuel filters aren't working right and fouling the pump.
-Replace the fuel filters. They are cheap and easy to swap out.
2. You're using a shitty aftermarket fuel pump like what Checker sells.
-Get an OEM fuel pump either from the dealership or go to Napa. Napa carries a Kyosan-Denki (OEM Brand) fuel pump in a Beck Arnley box. WELL worth the money.
James Henry
Wasatch Cruisers
TLCA 11233
76 FJ40 'SeldomSeen'
91 VZN130 'CanOWorms'
03-29-09, 07:09 PM
elec
Lots of vehicles using electrical. I used em on a couple of my cars in my teens I cant see why it wouldn't get you home although having said that I dont see an advantage in swapping you dont need additional fuel flow or anything
B Smith123
Haste maketh waste.
When the sun shineth, make hay.
Look ere ye leap.
John Heywood 1497-1580
71 FJ frame off build "UGLY BETTY" http://forum.ih8mud.com/40-55-series...y-betty-5.html
33 in BFGs, 4 inch HFS lift, Durabak, Paki Khaki top, Now sportin a RUNNING 2F and 4 speed!
03-29-09, 07:09 PM
Ramblin Wreck
Stick with mechanical, keep the electric in the toolbox for a spare.
I ran an electric for a few years when the original mechanical went out. It started to have intermittent issues and didn't seem to supply enough fuel at WOT, so I went back to the stock mechanical and tossed the electric in the spares box.
Not a huge deal, but worth considering is that if you have a mechanical fuel pump, the only 2 things that need 12v for the truck to drive is the coil and the idle solenoid. That gives you an impressive range if your alternator were to fail.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-P.T. 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'53 Willys Wagon
ΣΧ
03-29-09, 07:14 PM
I think the problem with the electric pump's where they would'nt flow enough, I bought the cheapest they had jsut to get him home, like I said it got him home but still is'nt right, we have the original on order, was just curious if anybody has used one with success like i said previously.. We had 2 pumps go bad one in my buddies PATH FINDER and my brother's FJ.. It was an all night ordeal just getting the NISSAn out of the hole was still fun....Stupid Nissan...
03-29-09, 11:13 PM
mech
Having said the electric will work (and they will) I personally would not install one when the mechs last forever it seems
Now the electric might be a good lightweight spare like you said
Have you considered the third option---A squeeze bulb?, but you need a passenger to operate it--but for a NISSAN owner that's the way to go
B Smith123
Haste maketh waste.
Look ere ye leap.
03-30-09, 01:36 PM
I told him to just leave the NISSAN where it died, and the wood's recovery team (vandals) would take care of the rest.....
03-30-09, 01:49 PM
#10 (permalink)
Pumpkinpete
After having trouble with the OEM mechanical pump i decided to switch over to a Mitsuba fuel pump.
No problems in the last 20 years........and it does have a filter element that can be changed if needed.
.........but i still carry a mechanical as a spare........
03-30-09, 06:30 PM
#11 (permalink)
Any Year/Model/Part Number you would care to share?
03-30-09, 06:44 PM
#12 (permalink)
i've heard they can rob at least 5hp. fan robs as much if not more. maybe not noticeable on a big engine... but that's 10 hp that you could run off your battery that is charging anyway.
michael vick is a loser.
03-30-09, 08:15 PM
#13 (permalink)
THC
I'm gonna have to quote you on that one.
No way a fuel pump uses 5hp. Maybe 1/5th of a hp.
If I had a stock carb I'd be running a stock pump. It just doesn't make sense to us anything else unless you cannot get a quality one in your area.
For $43 you just cannot beat the reliability. Plus, amazingly will bolt right up.
1976 TOYOTA - Fuel Pumps Products - All-foreign Car Parts
03-31-09, 02:11 AM
#15 (permalink)
Knight-errant
Pighead has never had a problem with the stock fuel pump...sees absolutely no reason whatsoever to change to electric. Unless one goes EFI.
04-09-09, 09:42 AM
#16 (permalink)
I use a Carter electric fuel pump on my 2f for about 8 years now, and i instal a fuel regulator (carter) set to it's lower pressure (4-5 pnds), I got no spliling issu or other trouble with it since then.
1980 FJ40 on 36" swampers SX
04-09-09, 10:32 AM
#17 (permalink)
I stuck a Mr.Gasket 12S on mine. Freaking mech pump went up in parking lot. I had a pressure reg sitting in box already. I have another factory pump ( NAPA BA )sitting in tool box now.
71 FJ40 DD/weekend masher
406 SBC/700R4/D300/4.88s
SOA w/37's.
Current build:
74 FJ40 DD project
383 SBC/700R4/D300/5.29s
SOA 38" MTZs
Proud supporter of our Troops and Vendors.
I can be your contact for Class III or SOT needs.
04-09-09, 11:02 AM
#18 (permalink)
I'm not aware of the brand electric pump I've got (PO install, judging from everything else the PO did, probably cannibalized from another truck) but it's noisy, and not-so-well wired in. Both mechanical and electric do the job, but the mechanical ones last forever. It's really up to you as for the final choice, but I'd say that if you plan on keeping that 2f stock, the OME pump and carb are designed for each other, and you'll get the best results by keeping the mech.
Phoenix: a blend of: '72, '78, '80, '86, '87 FJ40, 45, 60, 62, K5 Blazer.
No matter how long the arm of civilization gets, I'll always be just a step ahead.
10-27-09, 01:00 PM
#19 (permalink)
Location: Currently the middle east, but Georgia is home
I had 2 different mechanical fuel pump arms break off inside my oil pan on my last 2F. No idea why....
"WOW... That must've been some pants-poopin' impact ! .... -Spike Strip"
10-27-09, 01:23 PM
#20 (permalink)
In the garage
It happened because you were not running the spacer between the pump and block. I also vote for mechanical. I am still running the original pump in my 79 and just carry a spare for when it dies one day.
79 FJ40 & 78 FJ55
10-27-09, 02:33 PM
#21 (permalink)
mechanical pump for sure , they are way more reliable , easy to change and cheap .
of course i don't run a 2f , but the one on my small block has never given me problems .
i have changed several electric fuel pumps on trails / parking lots / side of the road / gravel pits / basically any were . i hate them , a good one is inside the fuel tank so that it is cooled properly . of course this makes it 5x more fun to change .
stick with the mechanical pump . buy a good oem one and carry a spare if your worried about it .
74 Fj40-350,sm420,60 series axles,36.5 swampers, aussie locked, saginaw.
10-27-09, 06:45 PM
#22 (permalink)
Lifer with a 2F-ETI
I run both, I use the mech factory pump as a lift pump to the surge tank and a bosch pump from the surge tank to the injectors.
The factory pumps are very reliable I have no issues using it.
If the wife's not complaining your not spending enought time with your 40!
2F+3FE+T+I-3F=2F-ETI
THE MULE Est @ +400hp @ 15PSI
DYNO'd at 8PSI 181kw/244hp & 560Nm/413ftlb @ the RW 8th Dec 08
EST @ FLY 283KW/379HP
Links
Mac's Space
On the rev limiter
Advanced (HB) Intercoolers
10-27-09, 07:36 PM
#23 (permalink)
On my 74 F I run the Kyosan mechanical and a belkamp electric pump inline just before it. I use the electric to fill the bowl when it's been sitting a while and goes emty. With the bowl filled I shut off the electric and it cranks right up. I run it on the mechanical alone but the electric is always there for a backup. 8-9 years with this setup on the aisin carb with no problems. The Kyosan just did start to drip so I just put on a new one. I'm also just now trying out a Weber 32/36. and I did the recomended fuel regulator but I couldn't get more than about one pound psi. So I ditched the regulator and I now get 3 - 3.75 psi with either pump or both together so again I'm happy with the dual pump setup.
74 FJ40 confined to the swamp.
