01-07-09, 02:57 PM
A rather dumb question......
I finally got my 40 situated in my garage and began correcting a few problems with it. One of the problems I have is a half-arsed SOA. I have the axle dropped and will be taking it to a reputable shop for a cut and turn. I need to have it stripped before I take it there. The problem I'm having is separating the 3rd member from the axle. Is there any trick to this or do I just beat the snot out of it until it comes loose?
I feel like such a noob.
I should've picked a better hobby. Slamming my junk in a drawer of full of razors would be more fun.
74 FJ40 - ready for a road trip
89 FJ62 - nicely modded
07 FJC - basically stock
01-07-09, 03:05 PM
Cruiserheads in training
Every time I have to remove the 3rd it is a PITA. If you can get a thin screwdriver or even a razor blade inbetween the housing and the 3rd it will start splitting apart.
74 FJ40 - 2F/PS/SM420/3spd/SOA/35's/Longfields/Hi-steer/Aussie F/Detorit R
TLCA # 12690
Elk Grove, CA
01-07-09, 03:10 PM
In the garage
Put your factory bottle jack under the third and use it to break the seal at the axle. It is a good idea to leave two nuts threaded on so the 3rd does not hit the garage floor when it breaks free.
I am not sure how a shop is going to be able to set the proper caster and pinion angle for you without the rest of the truck. If I were a shop I would certainly give you no guarantees the angles are going to be right. My guess is unless there is a LC specific shop near you who cuts and turns axles, when you tell the shop what you want done they will send you on your way.
79 FJ40 & 78 FJ55
01-07-09, 03:12 PM
When it's on the vehicle I have put a jack under the diff and lifted up a bit to pull it loose. You may be able to lay a hi-lift on the axle sideways wedged between the steering stop and the diff housing close to the pinion. But I would think a big deadblow might knock it loose. Maybe a ratchet strap around the knuckle and nose of the diff? Ghetto but it might work...
01-07-09, 03:13 PM
G8R H8R
I squirt mine down with gasket remover, wait about 15-20min. then do the same as JohnSmith. works every time.
'73 FJ55,'76 FJ40,'77 FJ40,
'77 FJ55,'78 FJ40,'83 FJ60...1 Wife, 1 Dog, 3 Cats.
too many Toy's.....too little time....
SAVE TELLICO!
01-07-09, 03:19 PM
Damn you guys are quick! Thanks for the input!! I'll start with the gasket remover and work in out from there! You guys are the goods!
01-07-09, 04:22 PM
Beagles Rule!
You did pull tha axles out, right?
01-07-09, 06:19 PM
I'm not that much of a Cruiser noob Dan!  I never had a chunk give me headaches like this before is all. So long as I can pull it out like a Ford 9 I'm good to go!
01-07-09, 06:22 PM
you p robably gotta do this first or it aint moving
01-07-09, 06:27 PM
#10 (permalink)
The guy I'm taking it too is someone Gumby trusts if that tells you anything. He's done similar work for a few Mud members and knows what needs to be done.
Oh and yes the axle shafts are pulled and sitting on my bench waiting to be Martacked.
01-08-09, 12:10 AM
#11 (permalink)
I found that once it is out of the vehicle all of the leveraging tricks didn't work. The third weights probably more than the entire axle housing. I put the axle housing on a bunch of wood, lifted the third by the pinion flange with an engine hoist till the housing was just off the wood. Placed a 4x4 on the flat part near the third and hit it with a sledge. It dropped onto the wood with two shots.
1960 FJ25, FI 350, SM420, Orion. lockers, ah crap... all the rest
2006 Chevy Duramax
01-08-09, 02:09 AM
#12 (permalink)
I have had success using a putty knife and beating it into the seam using a bfh. i do this at 12, 3, 6, and 9 oclock positions, and then I use 3-4 small screwdrivers to wedge it into the seam to pry it off. It will destroy the putty knife but I am 4 for 4 using this technique if you want to call that a technique
osseous manipulator
01-08-09, 02:36 AM
#13 (permalink)
also use the putty knife
