01-01-09, 04:24 PM
Dain Bramaged Member
Rear third problem
I'm having a hard time pulling my rear third member. I have an ARB RD08 locker, the cross shaft is out but I can't get the thrust block/spider block out.
It looks like the axles are interfering but I can't get them to move out.
Am I missing something?
Dan Johnson
What the large print giveth, the fine print taketh away.
Battle Born Cruisers
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.)
And a pair of Pink Panties, now with a doohicky in the front.
Rust never sleeps.
01-01-09, 04:48 PM
You pulled the pinion shaft. then pull the axles snug into recess in the side gear, pull out the thrust block and the ring around it, then push the axles in, remove the c clip, and pull the axles out.
It sounds weird Dan, it isn't a difficult operation, usually. Is the ring hanging up on the short shaft of the third pinion gear?
Maybe a pic?
Andrew
1984 FJ-60 H55f, 4.11, SOA, partially Rubicon tested
1989 FJ-62 122k-son's driver for now-low and slow
1997 FZJ-80 Driveway queen
01-01-09, 05:56 PM
Maybe a pic?
I can't get the axles to move out far enough to clear the thrust block. I have the wheels and drums off is there something I'm forgetting?
It's frustrating because I've done this a few times before. I was hoping to get the rear end done today and the front torn down tomorrow. I wanted to get the knuckle service done Saturday and your SST back to you next week.
Dan Johnson
Rust never sleeps.
01-01-09, 06:03 PM
No rush on the SST. All my trucks have a fairly fresh knuckle service!
If the block went in, it has to be able to slide out. So is the assembly catching on the back of the ring? The thrust block is already between the axles so by definition, it can't really be caught.
Andrew
01-01-09, 06:09 PM
Yes I think the ring is hanging up on the axles. The assembly moves out about 1/4" then stops.
Dan Johnson
Rust never sleeps.
01-01-09, 06:34 PM
Dan Johnson
Rust never sleeps.
01-02-09, 02:23 PM
Wierd, it came right out today.
Dan Johnson
Rust never sleeps.
01-02-09, 07:34 PM
Dog is my co-pilot.
Hi All:
"Rusty _TLC," glad to hear that you were able to get that diff pulled!
I read your posts, looked at the RD08 diagram, and could not think of anything array; I think that I would really need to look at the situation in person to have a constructive comment.
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
" The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
01-02-09, 08:11 PM
#10 (permalink)
Originally Posted by Josie'sLandCruiser
Hi All:
Regards,
Alan
It was just bizarre, I fought that bastid for hours yesterday. Then it almost fell out this morning. All I did was give both axles one more yank, I didn't feel any movement but they must have gone just that bit further that allowed the thrust block to come out.
The front diff is out of the rear axle and the repaired rear third is installed.
Dan Johnson
Rust never sleeps.
01-02-09, 08:15 PM
#11 (permalink)
what he said
Typical
01-02-09, 08:25 PM
#12 (permalink)
Originally Posted by Mace
Typical
I had a similar experience with my front motor mounts, fought the hell out of the DS for a whole afternoon. Finally gave up, walked away and drank a beer. The next day I nudged the motor and the bolt fell in place.
Dan Johnson
Rust never sleeps.
01-03-09, 06:38 AM
#13 (permalink)
Is your Cruiser a female???
01-03-09, 07:17 PM
#14 (permalink)
Aren't all cars?
My Dad told me years ago "If it has wheels or boob's it's going to be trouble."  .
Dan Johnson
Rust never sleeps.
