Go Back   IH8MUD Forums > Toyota Tech Forums > 40- & 55-Series Tech
Old 09-29-08, 08:19 PM   #1
xjnation's Avatar
refinishing fibergLAss top, fiberglass showing
Are the tops coated in a gel-cote? The coating is worn off in quite a few places to where the fiberglass matting is showing. The fiberglass is in great shape, otherwise. Thick coats of resin to refinish it? Can you buy gel-cote? I was just going to cover it in Line-x but we quit spraying a while back so no-go there. Suggestions? Thanks. Tim
1973 FJ40 currently frame off, getting 4.3 CFi/4L60E/NP-205 and FJ-62 power steering. SOA, 35x12.50 MT/Rs, FJ62 FDB. Brought back from the grave(traded a shotgun for it, if that tells you anything). Turning out to be a sick 40!!
Buildup Thread: ALMOST DONE!!!!!
http://forum.ih8mud.com/40-55-series...up-thread.html
Sanity is over-rated!!
xjnation is offline   Reply With Quote
Old 09-29-08, 08:39 PM   #2
JohnnyC's Avatar
TLCA# 2231
go to your nearest boat shop...they will have the stuff you need in small enough quanities to not kill your budget.
1974 FJ40 OEM Soft Top
(1) Child boy version
(1) Child girl version
(1) New boy Child, done as of 11/6/08
197 Wife
TLC FST Canvas & Maint: http://forum.ih8mud.com/40-55-series...soft-tops.html
JohnnyC is offline   Reply With Quote
Old 09-29-08, 08:46 PM   #3
JohnnyC's Avatar
TLCA# 2231
there is a type of filler ...cant remember the name and also there is gel-coat
here are some guys that come up that sound like they would have the stuff:
TOP GUN MARINE 417-725-1887
2019 Michael Ln
Nixa, MO 65714
11.2MI from Springfield
B & C BOAT REPAIR 417-724-0424
1404 S Main St
Nixa, MO 65714
B J BOAT REBUILDERS 417-725-1792
1228 N Kelly Ave
Nixa, MO 65714
197 Wife
Old 09-30-08, 12:26 AM   #4
xjnation's Avatar
Now thats service. Thanks.
Old 09-30-08, 01:01 AM   #5
Sssmmmokin!
MarcoPolo's Avatar
I'm sure this would be helpful down the road for someone looking to do the same or similiar.
EDIT your thread title : galss
Otherwise, this should probably be in schat............................................. ..maybe with 35% for the gal's
76'fj40 - Rancho Lift (kidney belt required), Detroit locker up front, Skyjacker Nitro 8000 shocks
2F 76,000+miles, comphy 2002 Celica seats
Thank_a_Vet_young_&_old
Allowed to run wild, neglected, or cultivated .... A man's mind brings forth... If no useful seeds are put into it , an abundance of useless weed seeds will fall into it , and will continue to produce their worthless kind ... James Allen
MarcoPolo is offline   Reply With Quote
Old 09-30-08, 09:35 AM   #6
TLCA# 11643
Fiberglass
Where a resperator.
kbill45 is offline   Reply With Quote
Old 09-30-08, 12:24 PM   #7
LSUfj's Avatar
Originally Posted by kbill45 View Post
Where a resperator.
over your nose/mouth....
75 FJ40, resto in progress
01 UZJ100 daily driver
LSUfj is offline   Reply With Quote
Old 09-30-08, 12:33 PM   #8
xjnation's Avatar
I was gunna, but I didn't.
Old 10-03-08, 12:28 AM   #9
Sssmmmokin!
MarcoPolo's Avatar
Can only mean one thing...
Certain death...
..of course it may be decades down the road
Old 10-03-08, 11:50 AM   #10
Great White North
mano002's Avatar
TLCA# 17052
I used to Fibreglass for a living and you can re-gelcoat the glass that is showing, but you need to sand any of the old gel-coat that you are going to cover with the new stuff, as there is wax in the gelcoat that will casue the new stuff to not stick properly. we used to buy all out material from an Industrial plastics company, that can sell you the wax and some powder to add to thicken up the gelcoat to do a better job covering all the hairs on the mat.
1978 FJ40, SR & SUA Fr, SOA Rr, Stock PS
Summer: 34x9.5 TSL. Winter: 35x12.5 BFG AT
Rocky Mountian Landcruiser Asssociation
mano002 is offline   Reply With Quote
Old 10-03-08, 12:27 PM   #11
Relaxation Therapist
Christeon's Avatar
So is the top gel coated or painted from the factory? I was going to sand mine re glass it, then paint it. I have done some gel coat repair before on a boat and was pretty straight foreword.
1971 FJ40 frame off in progress, no name, color undecided.
Christeon is offline   Reply With Quote
Old 10-03-08, 12:50 PM   #12
Great White North
mano002's Avatar
TLCA# 17052
The Gelcoat was likely sprayed into the mould they made the roof in. It's pretty hard to spray gelcoat on a fibreglass part and make it look good. When we were doing repairs on boats, we would spray the gelcoat on really thick, and then sand it smooth with a really fine grit paper, then use some wax on a polisher to add a protective layer. Toyota could have done it this way, but it's pretty labour intensive.
When you appply gelcoat, it usually has wax in it, so when it heats up and cures, the wax comes to the surface and creates a seal. you can get wax-less gelcoat as well, for spraying in moulds, so you can fibreglass onto the and the gelcoat comes with the fibreglass and doesn't stay on the mould.
I want to fibreglass on some structure to my hard-top, so it has built in roof racks, and then do the same thing, maybe it'll be a winter project.
Old 10-04-08, 08:05 PM   #13
1.25Ton's Avatar
Interlux (boat coatings supplier) yachtpaint.com makes a product called brightside that is enamel paint for fiberglass. This works great for cruiser tops. I brushed 2 coats on my top that had exposed fibers and the brush strokes went away. It looks like it was shot with gelcoat.
1.25Ton is offline   Reply With Quote
Работа в Канаде | Remortgages | Shares | Mortgage Calculator | Mortgage Calculator
