Old 09-04-08, 07:58 PM   #1 (permalink)
cruiseronly.com's Avatar
TLCA# 7820
oil use please help
I have been working on cruisers for a lot of years but this is new to me. I have a 77 fj40 with 44,000 miles. This thing runs perfect, comprestion is at mid 150's on all cyl, 19 in of vacume at idle. The problem is it uses a quart of oil in 30 miles??? It has no leaks(first one ever), pulls really strong, smokes on down hill and after idling. I have replaced valve seals and pcv system. i know the only thing left would be rings but it is just hard to believe. All spark plugs look like they are all clean and burning even. please help
cruiseronly.com is offline   Reply With Quote
Old 09-04-08, 08:02 PM   #2 (permalink)
Texx's Avatar
Something's fucktitious. Either it's had a valve job without rings, and the mileage is incorrect, or the rings are stuck due to so little usage over the years. Next thing to do is a cylinder leak down test. Could be burnt valve, also. That's very low mileage if it's true, and a whole lot of years sitting. Could be trouble.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored SOLD:( 03 Tacoma TRD SR5, Suzuki DR350 Sold :(
Texx is offline   Reply With Quote
Old 09-04-08, 08:30 PM   #3 (permalink)
donny paradise's Avatar
not connected with good compression as stated
'75 Fj40," Thunder"
'85 FJ60, " Dik da Rat"
'95 Fj80, "Money Pit"
donny paradise is offline   Reply With Quote
Old 09-05-08, 06:18 AM   #4 (permalink)
TLCA# 7820
valve
no, it is not posible that it is a burnt valve. the milage is corect. i could go with the stuck rings but all of them?
Old 09-05-08, 08:32 AM   #5 (permalink)
TLCA# 7820
anyone?
mark i saw that you went to running 6 qt of oil. did this stop the consumption or just the smoking? going to 6 just seems wrong. has anyone else tried this?
Old 09-05-08, 03:39 PM   #6 (permalink)
TLCA# 7820
help!!!!!!!!!
where are all of the smart guys?
Old 09-05-08, 03:53 PM   #7 (permalink)
lostmarbles's Avatar
Garage
Originally Posted by cruiseronly.com View Post
.... smokes on down hill and after idling. I have replaced valve seals......
Have another look at what you did here perhaps? Did you do something wrong or fail to notice something that wasn't right?
Name's really Tom & I have a 1979 Australian-market BJ40 that is RHD and mainly "original" with Toyota PTO winch, 16" split rims, drums all round, B engine, H41 transmission and 12V electrics that I've owned since 1981
A hood is really a bonnet. A fender is really a guard. A windshield is really a windscreen. A zerk is really a nipple. A tire is really a tyre...........
lostmarbles is online now   Reply With Quote
Old 09-05-08, 04:08 PM   #8 (permalink)
Oh...Durka Durka Durka.
Poser's Avatar
TLCA# 1856
Garage
You state you are consuming a quart of oil every 30 miles.
You are not leaking oil.
You are saying that you have 150#’s of compression across the cylinders.
You are saying that you have replaced the valve guide seals.
You are saying that the plugs are clean.
This statement is not consistent with internal oil consumption.
Old 09-05-08, 04:48 PM   #9 (permalink)
malcb's Avatar
How many miles / quarts have you done / used since the valve seals?
FJ45 '75 & FJ45 '76
Stafford - UK
malcb is offline   Reply With Quote
Old 09-05-08, 05:02 PM   #10 (permalink)
Fast Eddy's Avatar
TLCA# 18155
Maybe it's all sloshing around inside the valve cover?
トヨタさん、ありがとうございました。
My '78 FJ40 - '73 and '78 FJ40 parts FS - WTB:Olive (653) Bib and Windshield frame
Fast Eddy is offline   Reply With Quote
Old 09-05-08, 05:21 PM   #11 (permalink)
malcb's Avatar
If it has only been 30 miles and one quart I was wondering about a leak into the coolant, or rear seal, both not very likely but I think it's been using oil for longer than that.
The first post suggests the valve seals were done because of the excessive oil consumption so it can't be in the rocker/valve cover.. very odd, that much oil through the engine and it would be likely to spit oil out of the exhaust, plugs would be fouled etc.
FJ45 '75 & FJ45 '76
Stafford - UK
Old 09-05-08, 05:35 PM   #12 (permalink)
TLCA# 7820
this is all true and why i cant get a handle on the problem. i would like to add that it has great oil presure hot and cold. i just can not figure out the problem. thanks
Old 09-05-08, 06:01 PM   #13 (permalink)
amaurer's Avatar
Smoking downhill and after idle are still classic valve seal indicators. Could it be that your valve guides are so wrecked that the valve seals are not sealing or got beaten to death again on your first run?
1982 BJ42 "Krull" - DD
www.cruiseruser.com - Replacement gauges and custom knobs.
Have you met LonelyBot?
amaurer is offline   Reply With Quote
Old 09-05-08, 06:22 PM   #14 (permalink)
Dito sa bahay kubo ko
UltraFJ's Avatar
You could always just sell the POS to me for a $100.00 (+ shipping of course ). I'd be happy to track down the problem.
Lord knows my 40 is a perfect opposite of anything that makes sense.
1971 40
2005 100
2003 4Runner Pick up
Honda TMX 125cc w/ side car
UltraFJ is offline   Reply With Quote
Old 09-06-08, 06:52 AM   #15 (permalink)
TLCA# 7820
thanks for the offer, i was wanting to at least get 200. i realy hate to tear into a motor that runs this good. thanks
Old 09-06-08, 08:18 AM   #16 (permalink)
TLCA# 15247
Cool
I'm in a similar situation with my 79. 104k, compression tests between 135-150 hot, 19 inches at idle, runs good, decent power, etc. But it has used some oil since 82k when I bought it. Over the last 5k miles or so I have actually been noticing it smoking at times and began keeping track and it's using roughly a quart every 150 miles. So I bought a set of valve seals. Before I got a chance to install them I got a leak down tester and used it on the cruiser. It's telling me i've got basically 50-60 percent leak down, and it's all coming through the bottom end. Which makes sense considering the majority of the smoke I see is when it's cold, and whenever it's under a heavy load. I'm going to tear into it this fall for a complete rebuild/balance/cam/shave head/valve job/etc. and i'm expecting to find most of the rings stuck to the pistons. Which would make perfect sense considering the truck sat without being started for 7 years according to the previous owner. What I do find odd is that before the last 5k miles or so I never saw it smoke at all. Now it's smoking to the point it's kind of embarrasing to drive.
79 FJ40,85 Mustang GT,05 Tacoma,00 4Runner,89 pickup
ken_79-fj40 is offline   Reply With Quote
Old 09-06-08, 08:24 AM   #17 (permalink)
mikealeus's Avatar
TLCA# 15677
I agree with Amaurer, sounds like valve problems, I'm guessing the guides are allowing oil to be forced past them with the good compression you state you have.
1971 Freeborn Red FJ40 (sold) 1978 Mustard FJ40
2001 Silver Tundra 4WD
1963 SilverStreak
mikealeus is offline   Reply With Quote
Old 09-06-08, 05:08 PM   #18 (permalink)
I've a similar problem, compressions are 150,150,152,145,150 and 152. Vacuum is at 20 in hg. PCV vacuum test lowered cranking vacuum by 3. I ran synthetic in it until I found everyone here runs 20-50 dino oil so I changed to it and after 400 miles it still smokes at startup and under heavy loads. The engine was reported as a recent rebuilt by the seller. I'm losing about a qt. every 350 miles. I think it is the valve guide seals. I don't know how you can lose a qt. of oil in thirty miles w/o some kind of engine failure in the near future. Now I've also heard that synthetic oil glazes the cylinder walls but that must be with new rebuilt engines cause you wouldn't get high compression values...would you?
32x11.50 is offline   Reply With Quote
Old 09-06-08, 09:34 PM   #19 (permalink)
TLCA# 7820
I think i will just put a case of oil in the back and drive the hell out of it. Iam sure it must be stuck or broke oil rings, i just think i would see the oil on the plugs? I am driving it every day so maybe the problem will surface or the cruiser gods will just fix it on its on.
Old 09-07-08, 12:33 AM   #20 (permalink)
KOOTENAY KRUZER's Avatar
TLCA# 17298
cruiseronly.com -
The first engine I ever repaired was an 1100cc Volkswagen beetle. the dealer sold me a wrong set of rings and I put them in in my ignorance. All 4 oil control rings broke in about 100 miles and it burned a quart of oil in about 10 miles, big smoke screen behind but no noticeable loss in performance, the compression rings remained intact.
If one or more of your oil rings are stuck due to it sitting so long but all of your pistons have functioning compression rings I think you would get symptoms like you describe. Problems with stuck rings do not show up right away because at first they are still making contact with the cylinder walls, but they do not expand to compensate for wear so the clearances eventually get too big.
Wayne
1983 BJ42, SOA, Shackle Reversal, 4.11 diffs, locker in rear, Saginaw power steering, 33x12.5s. 4-wheel discs
1979 BJ40, 3"lift, 1982 BJ42 drivetrain, Saginaw ps, 32x10.5s, Warn 8274 winch
2001 Echo, stock
KOOTENAY KRUZER is offline   Reply With Quote
Old 09-07-08, 08:15 AM   #21 (permalink)
TLCA# 7820
Thanks Wayne. I realy think this is the only thing it can be. Has anyone ever had any luck with soaking the top of the pistons to free the rings up? Any chance with more daily use they may free up? I know i am reaching here but the thought of tearing down such a good running motor makes me sick. thanks
Old 09-07-08, 10:58 PM   #22 (permalink)
elder statesman
65swb45's Avatar
TLCA# 1086
Found your thread. Better to just send me a link next time.
As Poser and other have said, consumption, especially at that level, without evidence on the spark plugs, is very unlikely.
Drive it.
A carbureted man in a fuel injected world.
65SWB45, 64LWB45, 68FJ40,72V840, 76HJ45[gone],84FJ60[gone], 76K5, 73Sub454, 97Sub5.7, 2002 Trailblazer
TLCA delegate, Trail Crew-LAC TLCA, The White Trash of the Elwood Chapter
my website:
http://www.marksoffroad.net
IT'S FASTER if you CALL ME!
65swb45 is offline   Reply With Quote
Old 09-07-08, 11:14 PM   #23 (permalink)
Not so think as u drunk!
Hugh Heifer's Avatar
TLCA# 17468
Garage
No puddles on the driveway? Weird....
Hugh Heifer is offline   Reply With Quote
Old 09-08-08, 08:14 AM   #24 (permalink)
TLCA# 15247
I tried this on mine over last winter since I don't drive it in the salt. I would back it out of the garage, let it warm up, pull it back inside, pull all the plugs out quickly and put a turkey baster full of marvel mystery oil into each cylinder. I did this 3 or 4 times and went through 2 bottles of mystery oil doing so. In the spring I drained the oil and the first time I took it for a drive it was still smoking under load, and the oil consumption if anything got worse. Like you I have no signs of excessive oil consumption on my plugs. Due to my leak down test results I know it's rings, and it's getting torn down in a month or two to investigate further, and then i'm doing a rebuild. Mine has always turned fresh oil completely black within a few hundred miles too, another sign of worn rings. Yet it drives fine, I had it out yesterday and took my dog for a ride. If this truck sat for any period of time (which is very likely considering the mileage) it's probably got stuck oil rings. The machinist who is going to do the work on my motor says he sees this all the time on stuff that sits.
Old 09-08-08, 11:47 AM   #25 (permalink)
total rice
dgangle's Avatar
TLCA# 10793
It's evaporating!
Serioisly. If it isn't leaking oil externally or internally, the onlything left is burning it. I've had engines that used a lot less oil than that and they fouled plugs regularily. If this is not showing up yet you haven't waited long enough.
Something just doesn't add up.
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000 ROTW
2007 4 Runner SR5 4WD - stone stock daily driver
TLCA#10793
"The advent of the internet has permitted stupid people to propagate their stupidity WAY too easily, all with a position of self-proclaimed authority preying on peoples' ignorance or stupidity. Everyone with a keyboard is an expert." UNKNOWN
dgangle is offline   Reply With Quote
Old 09-08-08, 12:35 PM   #26 (permalink)
apeterson's Avatar
TLCA# 16605
subscribe...
because I want to see the answer when you find out...
My weekend friends love Top Gun... (Gay yes I know)
http://www.youtube.com/watch?v=xHklGtW3rwU
build thread http://forum.ih8mud.com/40-55-series...r-builder.html
apeterson is offline   Reply With Quote
Old 09-08-08, 04:00 PM   #27 (permalink)
"Which would make perfect sense considering the truck sat without being started for 7 years according to the previous owner. What I do find odd is that before the last 5k miles or so I never saw it smoke at all. Now it's smoking to the point it's kind of embarrasing to drive. "
My situation as well, pretty much, including a sooted up tailpipe and spark plugs that smell oily, and really low oil pressure. But it was running great. So it's torn down and in the machine shop right now. We found bad bearings, rings and worn cylinders. Yeah, pretty embarrassing blowing a cloud of smoke into the window of the Prius next to me.
igotta40 is offline   Reply With Quote
