Go Back   IH8MUD Forums > Toyota Tech Forums > 40- & 55-Series Tech
Old 08-27-08, 11:46 AM   #1 (permalink)
Smoke on start-up, oil additives?
I did a search, I promise, nothing that exactly answered my question:
F engine, runs great, oil pressure low at idle, but nothing knocks or rattles, and I'm not tearing this one down until something drastic occurs.
But I get a big puff of smoke at start-up, which I understand to mean my valve guide seals are worn. My wife is not happy, and I kind of get embarassed myself when an admiring person in the Home Depot parking lot waits for me to leave, and I see him waving the smoke away from his face as I pull away.
Is there an agreed-upon additive that minimizes this effect? If not, just say so, and I'll stop complaining about it.
'71 FJ55 Arizona truck
1 1/2" shackle lift, 33 x 9.50 BFG All-Terrains, 4-sp with Fairey overdrive, big brush guard with Warn 5687 (that doesn't work), otherwise bone stock.
brider is offline   Reply With Quote
Old 08-27-08, 11:50 AM   #2 (permalink)
ranger's Avatar
The additives are a waste of money. Pull the head off and get it redone.
ranger is offline   Reply With Quote
Old 08-27-08, 11:52 AM   #3 (permalink)
Fast Eddy's Avatar
TLCA# 18155
Worn valve guides that cause low oil pressure is "drastic". Fix it.
トヨタさん、ありがとうございました。
My '78 FJ40 - '73 and '78 FJ40 parts FS - WTB:Olive (653) Bib and Windshield frame
Whiskey makes me wanna fight. Tequila makes me wanna fight things that aren't there.
Fast Eddy is offline   Reply With Quote
Old 08-27-08, 12:19 PM   #4 (permalink)
I don't believe it's the worn valve guides (I suspected only seals, but maybe the guides themselves are worn, too) that is causing my low oil pressure, but it's not the pressure I'm worried about (still pumps up good at driving speeds).
But I get the drift-
Thanks guys!
Old 08-27-08, 05:23 PM   #5 (permalink)
Cruisin'
'69 Yota's Avatar
TLCA# 17230
Try one quart of power punch. You can get it at NAPA. It made a big difference in how much oil I was going through.
'69 Yota is offline   Reply With Quote
Old 08-27-08, 05:34 PM   #6 (permalink)
Sssmmmokin!
MarcoPolo's Avatar
Question
So is this less chances of a possible piston ring issue?
What would the % of one vs. the other be?
Thanx..... one on me
76'fj40 - Rancho Lift (kidney belt required), Detroit locker up front, Skyjacker Nitro 8000 shocks
Warn M8000, comphy 2002 Celica seats
Thank_a_Vet_young_&_old
Allowed to run wild, neglected, or cultivated .... A man's mind brings forth... If no useful seeds are put into it , an abundance of useless weed seeds will fall into it , and will continue to produce their worthless kind ... James Allen
MarcoPolo is offline   Reply With Quote
Old 08-27-08, 08:08 PM   #7 (permalink)
NCcruiser1970's Avatar
I say piston rings because of the low oil pressure.
Just looking for a "heep" to snack on...
NCcruiser1970 is offline   Reply With Quote
Old 08-27-08, 08:19 PM   #8 (permalink)
Sssmmmokin!
MarcoPolo's Avatar
That's why I asked..
Old 08-27-08, 09:39 PM   #9 (permalink)
handcannon's Avatar
TLCA# 19246
Rings have nothing to do with oil pressure. Main/rod/cam bearings do though. Worn rings can be part of oil burning along with worn valve guides/seals.
handcannon is offline   Reply With Quote
Old 08-27-08, 09:42 PM   #10 (permalink)
Ramblin Wreck
CruisinGA's Avatar
I assume his readings are off the stock gauge, if so, any discussion involving oil pressure is not worthwhile until there are some actual numbers from a mechanical gauge.
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 08-27-08, 10:47 PM   #11 (permalink)
splib's Avatar
If it's a heep owner waving the smoke from his face, then mash the throttle more!
No, really, X2 on the mechanical gauge.
Where is it registering besides idle? Is it only low on idle? If so, I'd say valve guides, that's what I found on the FJ60 I had with 220K miles on it.
Paul
'70 FJ 40-PARTING OUT
'72 FJ 40
'02 4WD Taco
'03 Corolla S
"Trying is the first step toward failure". - H. Simpson
splib is offline   Reply With Quote
Old 08-28-08, 04:20 AM   #12 (permalink)
Valve Stem Seals
I think your valve stem seals are worn.
When you shut down the engine, oil in the top end runs down the valve stem past the seal and accumulates in the intake and exhaust, above the valves. The oil will drain into your cylinder if the valve is open. When you fire it up, a bunch of oil has already run down and accumulated - it burns all at once.
These seals are better replaced with the head removed but could be replaced with the head on.
To do this, remove the rocker assy. Work on the valves in 1 cylinder at at time with the piston of that cylinder at TDC (so the valve doesn't fall in the cylinder bore). You can use constant air pressure being fed in through the spark plug port to hold the valve closed (up) while you work on it.
Replace all the seal caps that are located under the valve springs and re-assemble the rocker arm.
I think you may have to buy a complete engine gasket kit to get the new seals for the valve stems.
Don't expect improved oil pressure, but there shouldn't be a puff of blue smoke on start up.
good luck
desertpat is offline   Reply With Quote
Old 08-28-08, 05:13 AM   #13 (permalink)
Came in this morning and was suprised to find more entries on this thread!
Compression checks high and consistent, last I checked was 150-ish. This engine pulls steady 21-22 in. vacuum at idle.
I'm reading oil pressure from an aftermarket mechanical guage. Pressure is high at idle when cold, 50 psi+.
At hot road speed (misleading choice of words when talking about an F-engine 55), pressure is a comforting 30-40 psi.
Hot idle is low, maybe 10-15 psi, but the guage isn't that finely calibrated; the needle does drop to it's stop when I shut it off, so I know there IS pressure at idle.
But like I said, the pressure isn't my concern, I'll run this engine until it destroys itself, then look at it as an opportunity to upgrade to a 2F. My concern is the big cloud of smoke at startup. Thevalve seals sound like something I could do when the rig is down for the salt season. but if there was an additive that anyone had luck with, I'd like to try that now, while I'm still driving it.
THAT was my primary question.
Thanks!
Old 08-28-08, 08:44 AM   #14 (permalink)
Knight-errant
Pighead's Avatar
TLCA# 2509
For an oil additive, look for something with the word "Miracle" in the name...
Another way to tell if it is bad rings causing the smoke (and smoke on start-up is usually due to valve seals) is to coast down a long hill, in gear, punch it at the bottom of the hill and look for a cloud of smoke behind you. Big cloud=bad rings.
"Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55"
http://forum.ih8mud.com/424768-post9.html
Pighead is online now   Reply With Quote
Old 08-29-08, 08:52 PM   #15 (permalink)
Sssmmmokin!
MarcoPolo's Avatar
good luck
If this were the case, wouldn't the engine be running rough as well as having the smoke issue? I experience this and turned out to be so.
Old 08-30-08, 06:09 AM   #16 (permalink)
Marcopolo:
Now that you mention it, it DOES idle a little rough, and I have not been able to identify the cause from my vacuum guage readings. High vacuum, needle doesn't indicate worn rings, bad valve, OR bad valve guides (as the vac-guage literature says it should reveal). Also, it does not indicate ignition, but I plan on wapping over to an e-dizzy this winter. The carb was rebuilt by Jim C., so I don't suspect carburation.
Anyway, your point is a good one, maybe the bad seals are causing oil-richness at idle, making it idle a little rough?
Old 08-30-08, 08:17 AM   #17 (permalink)
amaurer's Avatar
FYI, here is my writeup/pics for swapping valve seals:
http://forum.ih8mud.com/diesel-tech-...ment-pics.html
Its on a 3B, but I'll bet it exactly the same...
www.cruiseruser.com -
Aftermarket Gauge Adapters for Stock Cluster, Customized Repro. Dash Knobs/Pulls, Customized Repro. Shift Knobs, Flip-down Radio Delete Gauge Pod, Popout FJ40 Tent Plans
"... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908
1982 BJ42 "Krull"
amaurer is offline   Reply With Quote
vBulletin® v3.8.3 ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
