07-22-08, 02:17 PM
rear disc with arb locker
Hey guys, i was just starting my rear disc conversion when in the first step i ran into a problem. I don't know how to take my c clips off the axle for removal. I know how to do an open carrier, but not a arb locked one. Thanks.
79 fj40- 2F-TBI , 4:88 R/P, ARB Front/Aussie rear, SOA, 38 TSLs, Full Cage, Bobby Longed SS, Saginaw Hi-Steer, SM465/3speed tcase, 4WDB, 97 wheelbase, fj55 springs, and some spares, it's MUSTARD YELLOW
07-22-08, 02:26 PM
I can mangle anything...
ARB says to push the axle shaft in a bit and then you should see the C-Clip
Claudia
'72FJ40 with a no-number 2F, MAF headers, 4spd, 33x10.5 BFG MT, 4" lift, roll cage, prehistoric ARB lockers f/r, MAF disk brakes f/r, hand throttle, Painless wiring, CB, custom horn brush, dual advance dizzy, Bilsteins, 4+ front bumper/rear shackles/U-bolt flip, Kevin-improved frame/shackles/shackle hanger, several polished turds  , with ChaseTruck  yes, MANUAL steering
Copper State Cruisers #40
http://www.desertrider.net/
07-22-08, 02:41 PM
pretty much the same concepts. the idea is to get to the c-clips
unscew the cross shaft retaining pin
remove the cross shaft
remove the spider block and thrust block
then you should have access to the c-clips.
(sorry if i forgot some steps)
heres a breakdown assuming you are using rd124
http://www.arbusa.com/alac/alsp/2-RD124.pdf
07-22-08, 03:05 PM
IH8MUD VOYEUR
How old is the ARB carrier? I have a set of older ones and a set of newer ones and they vary... they both have a kinda hidden shaft/bolt that locks the cross shaft in place and it is inside/underneath one of the carrier housing bolts. Is this making any sense? On the newer it has its own bolt/hole. To get it (shaft/bolt) out you either need the ARB removal tool or a screw about 4" long and I think the thread is 11/32" now what you do in screw this screw into the carrier housing bolt hole in it will thread into the shaft/bolt, then spin the pinion shaft back and forth while you pull on the screw... should pull right out!
When I was doing mine I couldnt figure it out either, ARB's website wasnt very helpfull either? I searched and searched on here and finnally figured it out, kinda surprised there is nothing in FAQ
Anyway, hope this helps... I'll see if I got any pics
-'76 FJ55-ARB's/4x4labs/Longs/60ps/60axles/36's/SOA/H55/Custom Awesome Driver!
-Matching FJ55 Trailer-ARB RTT/ARB Fridge/Same 36's/ trailer-being setup for long range travel/Basecamp
-'89 FJ62-350/700R4/reversal/33's/18"Mojave's/blacked out
-'69 FJ40-Now on 40's/SOA/60 axles w-ARB's/60ps/ 60 springs/4x4Labs... installed soon
See my Land Cruisers Myspace @ http://www.myspace.com/hicruisefiftyfive
07-22-08, 03:08 PM
Like he said - you need that screw or the ARB tool. Both work - the screw just takes more luck  .
"The devil made me do it the first time. The second time I done it on my own."
07-22-08, 03:20 PM
IH8MUD VOYEUR
Found some, this pics are of the newer style and has a designated bolt/hole for the shaft/bolt. IIRC the older style the shaft/bolt is just under one of the carrier/housing bolts.
Hope this helps
07-22-08, 03:25 PM
correct, and the "tool" is a metric Allen wrench for very early models; they don't have threads in the retaining pin
however, with newer models, ARB told me you should be able to see the C-Clip
Claudia
07-22-08, 03:51 PM
thanks alot guys, i got the allen head screw off, now i'm off to lowes to get the screw, i'll let yall know how it goes. I hope the pin clears my 4:88 gears.
07-22-08, 04:07 PM
IH8MUD VOYEUR
Is that a grinder I hear
07-22-08, 04:11 PM
#10 (permalink)
Oh...Durka Durka Durka.
One of the teeth had to be ground in order for it to be installed and working currently...
07-22-08, 04:16 PM
#11 (permalink)
I just sawzalled off the backing plates.......
Ed
My Anger-Management Class really pisses me off
'66FJ40, Fresh 2F, H42/Orion(By Poser... LCR4WD), ARB Front/rear(By Poser... LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers, WhiteKnuckle sliders
07-22-08, 04:19 PM
#12 (permalink)
i had to grind with my 488s
07-23-08, 09:52 AM
#13 (permalink)
Ed
X2....this is what I did too ... is all that trouble worth the 5 bucks your going to sell them for on ebay for?
07-23-08, 10:30 AM
#14 (permalink)
In the garage
x3, when I did mine I cut them off and saved the hassle also. I did not think anyone would even want them.
79 FJ40 & 78 FJ55
07-23-08, 11:10 AM
#15 (permalink)
Hope this helps
where did you purchase that screw removal from? Lowes didn't have anything larger than a 10/32? Do i just stick it in the hole and spin or is there a trick to it.
07-23-08, 11:24 AM
#16 (permalink)
10/32 isn't a screw size. 10-32 is (I'm assuming that's what he meant when he wrote 11/32 ? ). 10-32 is a screw of #10 diameter (0.190"), with 32 threads per inch. #10 screws also come in a coarse-thread variety: 10-24.
-Eric
64 FJ40, slightly modified.
96 LX450, locked.
07-23-08, 01:01 PM
#17 (permalink)
i called arb, and they helped me, very good customer service, he even offered to send the tool to me for free, but i told him i couldn't wait, so he told me to use a narrow picking tool, and it worked! Thanks for everyones help.
07-23-08, 01:04 PM
#18 (permalink)
like these, worked perfectly
07-23-08, 02:27 PM
#19 (permalink)
you still got them to send the tool right? for future uses.
but it is nice to hear about good custmer service.
