Yesterday I was working on reassembling the 2F starter I had taken apart and while looking for some missing pieces I ran across my defective OEM dimmer switch. Pic #1
I finished the starter, installed it temporarily( FJ60 starter planned) and grabbed the dimmer switch for a closer inspection. I gave it a quick blast with the sand blaster then tried to figure out how to get into it. It is of course pot metal. The switch guts are held in placed by a lip that was pressed inward to hold them. The Dremel with a cut off wheel made short work of the lip. Pic #2. The guts just lift out. There are two main pieces, the top piece with the wire attaching posts, and the rotating switch plate. Pic #3 __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Sweet!
__________________ 9/70 FJ40 +Rollbar 9/64 FJ45 (L) P-B with restored wiring 4/84 Toy 4x4 Mini PU "The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton |
Pic #4 Next I used the Dremel to cut the head off the rivet holding the switch mechanism. Only take enough off to use a pin punch to pop it out, you have to have enough of the stud left to re-expand it when reassembling!
Pic#5-6. Here are the remaining parts that come out leaving just the shell. Clean everything in hot soapy water, then use a Dremel tool with a wires wheel to clean the switch contacts and any stubborn grease or corrosion. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Come on Dave, give me a break! (Old Van Halen lyric...)
My switch would 'hang' between high and low, due to wear on the switch plate, and the little tab shown in Pic# 7 had lost it's original shape. I used the Dremel with a sand paper disk to dress the gouges on the switch plate (Pic #8) and bent the tab back into shape. I then put some dielectric grease everywhere I saw wear and put the switch plate back in.
Pic #9 shows a critical view. See the circled area? The switch plate is actually two plates with a space between them, that little arm MUST go between the plates AND to the left side. Any other way and it won't ratchet correctly! __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Once I was happy with the operation I flipped it over, put some support under the rivet then used a pin punch to expand the end enough to hold it in place. I also later filled the hole with epoxy. Sorry no pic of that operation...
![]() Pic #10 shows the proper placement of the spring that goes between the switch plat and the switch contacts. Pic #11 shows the switch contacts in their proper orientation. If you get this wrong the switch will not work at all! Pic #12 shows the final piece with a good coating of dielectric grease. This piece has an alignment tab so it will only go in one way. __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Pic #13 Get a small C-Clamp and clamp the top piece in position. Mix up your favorite brand of epoxy and place the epoxy all around the edge. Let dry 24 hours and you have a switch that will last another 35 years!
![]() Forgot to mention that I powder coated the body chrome and the button chrome with translucent gold overlay.. ![]() Enjoy! __________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Mobile Phone | Best Credit Cards | Compare Credit Cards | Personal Loans | TV News |
