74 fj40 top speed
i have a 74 fj40 with orig 6 cyl it runs and drives good only prob is top speed is to slow for all the afterburners on highway it will keep up but i dont like running it that hard any suggestions would be appreciated 4-11 gears i think
Do like I do, and probably most on here, stay in the right lane and go slow....Since I used to be a sports car guy, I've found that because the FJ is so slow, it has eliminated my road rage tendencies....
__________________ 74' FJ40 Freeborn Red, 114kmi, 31x9.50 ssTSLs on stock steelies, stock, except non USA Dist. Awesome. |
what he said
It will do 70 all day long as long as it is running in reasonable tune.
__________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
myopic luddite
Why do you feel you have to go fast? Peer pressure?
I know my Pig will do 80mph, but it doesn't like it, I don't care for it either. I drive 55. People go around me. If I can find a nice big truck doing 55 I'll settle into it's draft and stay there. Slow is good. __________________ "Well it's a '68, '69, '70, '71, '72, '73, '74, '75, 76, '77 FJ55" http://forum.ih8mud.com/424768-post9.html |
Leave earlier.......... hard to beat the sound of a finely tuned F/2F at 55mph......
__________________ Stuff ALL HALE THE F/2F 1994 FZJ80 Every Day GG 1965 FJ40 Stock, DQ Sunday fun truck 1984 FJ60 Cabin Cruzer LOTS OF FJ40 PARTS FOR SALE http://forum.ih8mud.com/sale-parts/2...ml#post3472352 |
Get use to the slow lane or buy a 5spd.
__________________ Student of the PIGG '68 FJ55 '72 FJ55 '73 FJ40< newest addition "Fish on!".
My 74 can hit 70 at a bit over 3k rpm, with 31 inch rubber overdrive.
For safety reasons I don't go over 60 usually. Not worth the reduced handling and gas mileage to go faster. __________________ 1974 FJ40 Penelope, beat up stocker, FJ60 knuckles. 2001 Silverado step side 2008 Giant Trance X2 2005 Specialized Hardrock Sport |
#8 | |
I pushed my '73 past 70 going through Denver long ago and it was anything but fun, loose steering and ruts in the road made for a terrible experience. If you are looking for better road RPM's you can drop your gearing but then the I-6 may start to feel a little sluggish. Rubber overdrive, maybe 3.73 diff's than maybe a 5 speed or auto w/OD. |
#10 |
yep purrs liike a kitty at 55 or so dont want to stress it any more than that just thinkin
#11 |
mine is lock stock purrs at 55 just wanted to see what the word was about more speed im fine where i sit just love the looks i get on the one laners with a line behind, but they will get over it thanks GE
#12 |
brett
to change gears to 373 a big deal or no and what about availability of getting them |
#13 |
Keep the 4:11's They are better!
I cruise at 55-60 and don't care who gives what kind of look. They can , as my daughter says, "build a bridge and get over it!"
__________________ 1978 FJ40 1985 4Runner |
#14 |
I have 4.11's + 31" tires and choose to cruise at 55mph/2790rpm.
62mph/~3100rpm is easily possible, but I don't like to cruise that high (but I'm diesel, maybe a gasser would be fine at the higher rpms, dunno). Here by San Fran 55 is just fine in the right lane. In Chicago I'd be a speedbump in someone's rearview mirror... __________________ "... the motor car, after woman, is the most fragile and capricious thing on earth." - London Daily Mail 1908 1982 BJ42 "Krull" |
#15 | |
__________________ Nathan 73 FJ40 ![]() ![]() ![]() 1997 FZJ80 DD Did you ever notice that when you blow in a dog's face, he gets mad at you, but when you take him for a car ride, he sticks his head out the window? |
#16 | |
Dan Dare!
Thats what pull outs are for. If I see three or more cars behind me I use a pullout.
__________________ Dan Johnson Quote:
FJ40, A couple of thingamajigs and a deally bob, fully integrated whatzits, dash board Hula girl (pending spousal approval.) And a pair of Pink Panties, now with a doohicky in the front. Rust never sleeps. .- -.. --... -. .-- |
#17 |
I have a 73 with the stock 3 speed and 50mph sounds like it is screaming. Believe it still has the 4.11, but without a tach not sure how fast she is turning. I have P265/75R15's on her now. Any ideas?
#18 |
springfield user
nobody said it, so i will.
it'll cruise 85mph on the highway all day long. __________________ it's only metal, we can out think it. 77-fj40 20th anniversary edition 87-fj60 216K mile DDer 93-fzj80 mall crawler toyota material distribution center. your source for Factory Service Manuals. they're alot cheaper than you think. 1-800-622-2033 |
#19 |
springfield user
3rd gear/top gear. is 1-1. i'll ball park it at around 3K rpm. you still have 1500ish till red line.
#20 |
i have not had my 74 fj40 for long changed oil filter, checked brakes and fluids probably need to change brake master cylinder it is leaking a little in front of the fill chanbers where they bolt on. also need to check front and rear axles any advice or help would be appreciated.
#21 |
Change the rear diff gear oil. The rear diff is in use full time. It needs new oil.
Change the transmission oil. Same reason as above. Check the front diff oil. Doesn't need replacing as often, but if it's sludgy, you'll need to rebuild the steering knuckles. Sorry, but it's one of those things every owner puts off. And now you own it. You can put it off too, but you should at least find out where you stand. ![]() (I put it off for a couple of years. Finally got around to it after sweating through a couple months of death wobble. YMMV) ps - Welcome to mud
__________________ The garage is no place to park an automobile. (TLCA-14131) |
#22 |
thanks theo the knuckles a big deal ? suggestions about brake master cylinder ie hard to change out or no
#23 |
Brake master isn't too bad. You have to be aware of the clearance/adjustment on the actuator rod and getting all the air out of the system.
The knuckles are kind of a big, messy job. No special tools if you're starting from a working assembly (like you are). If you find out you need to do it, you'll want to study up first so you do it right the first time. On the other hand, you can ignore the knuckles for quite awhile and still be OK. They won't fall apart on the road; usually your steering and handling will deteriorate gradually. Search will get you all the technical info you need on those two jobs.
#24 |
KI6MIE
I could not agree more with the go slow advice. Even if the motor is good for 85mph the chassis is not safe at that speed. I treat 65mph as an upper limit. It's a short wheelbase high COG truck. Go slow, stay within the braking envelope and enjoy. Get a car if you want to go 70+.
__________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#25 |
thanks cdrew i have no prob with going slow i just thought about stress on engine and driveline i am used to driving a diesel truck at about 1700 rpm at 65 or so and now im guessing im at about 2700-3000 at 55 but hard to tell no tach and all just want to keep her together as long as possible
#26 |
top speed
I have a 3b diesel in my 1981 Bj42 and 100 km per hr appx 62 mph is about as hard as I want t charge in my cruiser.
__________________ 1981 BJ42 |
#27 |
i usually hang around 55 or 60 with my '76, but i can push it to at least ~70 befor the belt starts to whistle. if i got a smaller belt i could maybe hit 80, but since all the highways around here top out at 65 theres not much reason to push the engin that hard. i get on i-10 and drive 55 in the right lane. kinda reminds me of a foghat song...
#28 |
ya wells jack the few times i have been on my end of i-10 the eighteen wheelers seem to take the most offense with the speed but they can just live with it. ps i'm as far to the east on i-10 as you can get and still stay in texas town called Orange
#29 |
I routinely drive my 76 FJ40 at 65-70mph.
35" tires, 3200 rpms, 4th gear. With the saginaw power steering, tight steering components, and good spring bushings, I can drive it that fast with 3 fingers on the steering wheel (obviously I don't drive that way all the time, but I think you get the point). __________________ James Henry Wasatch Cruisers TLCA 11233 76 FJ40 'SeldomSeen' 91 VZN130 'CanOWorms' |
#30 |
i'm on 31's winding a little tight for me at that speed anyone know what red line is on a 2f like mine ?
