Gas tanks
Sorry, could not find what I was looking for in search.
Looking for a spare gas tank for my '64, don't know how much longer mine will last. Up to what year did Toyota make the same gas tank as found in my '64 40? Thanks __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! |
I ordered one for my '67 from Toyota (Dan, specifically). He could only look it up back to 1969, but it worked in my '67 just fine. Couldn't be happier. Hope this helps.
__________________ '67 FJ40, TBI 350, NV4500, stock 3 speed transfer case, 30 spine long's, ARB rear, FZJ80 rear e-locker in the front, SOA cut and turned, 37" MTR's, in need of a lot of TLC... |
IH8MUD FREAKin' Addict
According to Spector, 1958-1967 are the same - Specter Off-Road-Land Cruiser Parts - Search On-168-09.
Good luck! ![]() __________________ '71 fj40 w/ 23k miles, carb rebuilt and ported by 65swb45, SOR 2 piece header, vacuum advance w/ pertronix, Hell Creek 4" lift w/ homemade shackles sitting on 33s, front disk conversion. ROTW "Yeah, we're runnin' a little bit hot tonight. I can barely see the road from the heat comin' off. I reach down between my legs n' ease the seat back. She's runnin', I'm flyin'!" |
#4 | |
Maybe a '67 tank will work...you still have a part number? __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! |
I really think a 61 thru 72 would fit. 58 thru 60 (FJ25) the tunnel cover is wide all the way back on the passinger's side not cut in like the FJ40. So I doubt a FJ40 tank would fit. The FJ25 soft top model has a totally different filler neck. The tanks in the later ones (71/72?) have extra emissions ports that would have to pluged.
John Dean measure the filler gauge I'm not sure which one the 64 has. The early one is smaller. Tell me the size and I will let you know which one you have. I guessing if your's is a early 64 it may be the small one. John |
Hi John,
She's supposed to be a Nov '63 manufactered '64...sent you a pm. Thanks __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! |
#7 | |
The filler was the same all the way thru 72. The ring size of the float changed around 64. The larger later style I think can still be had new. I think you may have to match the float to the gauge. If that's true you will have to replace the guage if you have to go to the larger float.John Just checked SOR site. They show the same fuel gauge early all the eay thru 72 but sending unit (float) changing starting in 66. Old style discontinued/Used $35.00 but none in stock. But if this is true you won't have to change your gauge if you get a later tank with the larger sending unit. Last edited by Living in the Past; 07-04-08 at 06:29 PM. |
Hmmm...not so simple a question was it.
I was kind of hoping I could find the replacements before I tried to take things apart. I'll try and get some more info off the tank this week-end...if I'm having this much fun with an old 40, well I just can't wait to start the 25!!! ![]() __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! Last edited by My wife said no FJ!; 07-04-08 at 08:55 PM. |
#9 | |
#10 |
the pre 67 is unobtainable new. Look at the POR gas tank refinisher systems. Like Kreem for a motorcycle tank, but more of it. If you need a donor early tank (that will need to be refinished) I might know a guy in VT with one. I had mine professionally done and it lasted 2 years, costing the same as a new 71 tank. Definately not worth it.
RedKote make a tank refinishing system as well |
#11 | |
Not that I need to justify...but I am looking for a spare tank for a serious restoration project, and wondered exactly what year model to look for to see if I could find a new one...I now know that had mine been a later '64 model I could have used '67, but seeing as it's an early '64, I need to find a clean used '63 and older tank. I don't know what's up with you.........really don't appreciate your fawking comment. __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! Last edited by My wife said no FJ!; 07-05-08 at 07:09 AM. Reason: censored my own post! |
#12 | |
When you say 'you know a guy in VT', do you mean Tyke? I spoke with Tyke, and he didn't have any spare tanks...I'll probably need to find one from the south west somewhere. Basically I don't want to finish this restoration, and have the tank go bad on me in a few years...if you have any other contacts in VT, then please send me their coordinates. Thanks for the info ![]() __________________ Dean 1964 FJ40 Hard Top...resto, going back to original stock! |
#13 |
nope, that was him. He had one, must have sold it.
Might try stuart Levassuer, he had a 67 he is parting. I will get you his email. |
#14 |
My first response was also not considering that this will be a full resto. I'm 99% positive that you can no longer get a new, older style tank from Toyota. Only the later style, which, as I stated, will work in an early FJ40 (at least in a '67). Not resto correct, though, I can't remember what is actually different.
Maybe there are still some lucky NOS deals out there. Not sure how long the older tank has been discontinued. __________________ '67 FJ40, TBI 350, NV4500, stock 3 speed transfer case, 30 spine long's, ARB rear, FZJ80 rear e-locker in the front, SOA cut and turned, 37" MTR's, in need of a lot of TLC... |
#15 |
The refinishing kits work well if the tank isn't too rough. I'm very happy with the results I had from Eastwood's kit in an old MG.
Depending on how much rust through you have, it may be worth it to weld in new metal. Obviously, if you don't know exactly what this requires, hire someone who does. |
Loans | Free Ringtones | Loans | Ugg | Car Insurance |
