Old 07-03-08, 03:35 PM   #1
Gregor's Avatar
TLCA# 14921
On my 3rd clutch master cylinder. Why??
I had master & slave cylinder replaced in 4/00 (shortly after purchase of FJ40). Replaced master cylinder again in 4/05 & again 6/08. It has never leaked before going out either.
I don't know much about clutch so have always taken to mechanic for repair. I don't know if the first 2 times I replaced w/ rebuilt parts or not. This time I got new Toyota master.
Could it be synthetic fluid causing the problem? Maybe problem related to being chevota?
I have searched & there are literally a couple hundred posts about master cylinder, but not really finding anything causing repeated problem except perhaps synthetic fluid.
Anyone have ideas or seen a thread that could answer my question?
Thanks!!
Gregor is offline   Reply With Quote
Old 07-03-08, 03:38 PM   #2
Gregor's Avatar
TLCA# 14921
Forgot to mention rig details:
77' FJ40, Chevy 350, 4" suspension lift, power steering, disk brakes, toy tranny
In notes I took in 2000, I wrote that slave cylinder is Chevy - not sure if that is correct or not
Old 07-03-08, 03:41 PM   #3
That's not too abnormal for wear, really.
When I ran DOT 5 synthetic fluid, the bore wear was insane. Moved back to DOT 3 and new parts and it's much better. Keep your DOT 3 changed out every 2 years or more.
If you want longer life, get a good cylinder sleeved with stainless steel. The stainless won't corrode, and it's smoother (less wear) for the seals to run along.
~John
Check out our new location in Duncan, BC
www.raddcruisers.ca
--> 60 Series Cable Lockers available - 4.11s or 3.70s - all hardware included
Limited Quantities - Deposit or Full Payment Required to hold your order while they ship
Radd Cruisers is online now   Reply With Quote
Electricity | Loans | Mortgage | Ringtones | Personal Injury Lawyer Los Angeles
