Ujoints/driveshafts
I finished the 4spd swap in my 72 about 3 months ago... And in that time totaly forgot about D-shafts. I tore the orignals down and primed them up then realized they are too short/long.
I have a brand new set of ujoints for the orignal shafts that I had planed on swaping in. My question is can I rebuild these shafts with the 'wider' bolt pattern flanges to fit the existing pinion&tcase flanges or are the parts difrent for the later trucks? I just wanna this thing...
__________________ My life is like trying to swallow a pine cone its tough when you live fast just to die slow. ~Shinoda Build thread: updated 2/23 http://forum.ih8mud.com/showthread.php?t=169539 |
Dog is my co-pilot.
Hi All:
You could re-build your existing drive shafts with the new u-joints then have the tubes modified to fit your new tranny/t-case combo. If you are running the original "three-speed" t-case the existing flanges on the drive shafts should be fine. If you used the "four-speed" t-case that came with the H41/42 tranny then yes you will need to switch the t-case end of the 'shafts to the "four speed" pattern yokes. Clear as MUD? Good luck! Alan |
__________________ '73 FJ40- F power plant- " HI-Ho, Silver Away!" "puff "of blue smoke on start-up, "puff" of black smoke when I frog it, but I'm work'n on it! (It's All About Love! )
I know what you mean when you wanna drive this thing!
__________________ These "roll" with me: 1973 FJ55 Toyota Landcruiser Restoration Project 2001 Toyota Tundra 2007 FJ Cruiser Seattle Cruiser Heads |
#5 | |
I have ben working on this thing for almost 2 years now (got the frame back from the galvi guys exactly a year ago) and its gettin to the point where the drivetrain is coming together etc. The body is almost ready for paint and I can see the light at the end of the tunnel. Some times I wish I wasnt so picky LOL __________________ My life is like trying to swallow a pine cone its tough when you live fast just to die slow. ~Shinoda Build thread: updated 2/23 http://forum.ih8mud.com/showthread.php?t=169539 |
#6 | |
__________________ 67 fj40, Chevy 350 SM420 Trans Saginaw PS S-A-W Racerunner coilovers 3 linked front 4 linked rear Currie Antirock FJ80 axles longfields ARB lockers front and rear Warn 9000 37x13.50 Xterrains and so on and so on.............. |
You cannot just bolt in 4 speed shafts as the bolt pattern isn't the same... there is a chart somewhere that breaks down the differences, can't find it right now. According to SOR and cruiser outfitters, the u-joint changed in '74 which is right around when the 4 speed came out so it seems that you could not create a mix 3-speed/4-speed drive shaft, you have to make the changes on the xfer and pinion flanges and change shafts or re-tube. The 4-speed shafts/flanges is a stronger setup.
Keep going... the light will get brighter! Eric |
Noaccount Webwheeler
From Cruiseroutfitters................................. ..
GL Ed Had mine retubed for $35@ __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
#9 | |
Dog is my co-pilot.
Hi All:
Sorry dude - if you still have the '72-vintage diffs, and a "three-speed" t-case you will need to use all old-school pattern flanges. I am personally using a mix n' match - old style diff flange pattern along with the newer four-speed pattern. So, the drive shafts use the old-style bolt pattern at the diffs, and the newer style at the t-case. This works by mixing 'n matching drive shaft parts from different year 1970s-vintage Land Cruisers. Since you are using all three-speed parts you will probably need to have your three-speed drive shafts lengthened to work with the longer drivetrain in your truck. Good luck! Alan ------------------------------------------------------------------------------ Quote:
#10 |
If you want all stock parts then order the course spline flanges from Cruiser Outfitters for the front and rear axles and the front t-case output then find a set of 4 speed drive shafts and a 4 speed t-case e-brake drum. That will give you all Toyota stuff so if you pretzel a shaft on the trail you won't be stuck trying to locate a bastard drive shaft that only fits your rig.
You should be able to buy all the parts cheaper than you can have your shafts modified, and will end up with stronger shafts. Then sell your existing shafts and the new u-joints to recover some of your costs.
__________________ !Oy my 1971 FJ40 Not Road Legal http://tinyurl.com/47zpb (My Web Site) http://tinyurl.com/2h6hc7 (Nut and Bolt Spreadsheet) |
Samsung | Samsung | Credit Cards | Debt Consolidation | Motorcycle Insurance UK |
