slide hammer rear bearing puller or what?
I'm replacing the bearings, so I can destroy the old ones. Should I take the time to source a slide hammer with puller or yank out the 3d and run a pipe through that MF'er and knock them out? One is already destroyed and just the cage is in there. half the 3d is out as I've obviously yanked the inners.
If I had a welder i'd weld them and they'd fall out, I know..... At this point I want them OUT.
__________________ 1/75 FJ40 (soon to be V8 converted) 88 FJ62 Bionic Blue TLCA Member # 17731 Treat me good, I'll treat you better. Treat me bad, I'll treat you worse. |
The pipe method is about 5011 million times easier.
or
you could try to talk a buddy into trying the slide hammer method, while you frink a few beers, then when that quits being amusing, you can use the pipe method, which is really the only way to go if you already have the center out.
Noaccount Webwheeler
I borrowed a slide hammer from the AP store and had no problems. PinHead also suggests running a weld bead on the outer race and the shrinkage will let it fall out.
GL Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
What about heating with a propane torch........just curious. I'm about "this far" from removing the 3d and going for the pipe.....
GSMTR Chair
Pipe takes all of 2 seconds.
__________________ Marshall Upstate Cruisers The Great Cruiser Part Links Thread Buying a Land Cruiser Guide 73 Fj55 Big Ugly 76 FJ40 ROTW Big Gay 2f Build 75 FJ55 My Build 93 FZJ80 stock everything and staying that way. |
Compare | Libro arquitectura | Myspace Backgrounds | Mortgage Calculator | Credit Report |
