Old 07-01-08, 03:34 PM   #1
alex e's Avatar
slide hammer rear bearing puller or what?
I'm replacing the bearings, so I can destroy the old ones. Should I take the time to source a slide hammer with puller or yank out the 3d and run a pipe through that MF'er and knock them out? One is already destroyed and just the cage is in there. half the 3d is out as I've obviously yanked the inners.
If I had a welder i'd weld them and they'd fall out, I know.....
At this point I want them OUT.
1/75 FJ40 (soon to be V8 converted)
88 FJ62 Bionic Blue
TLCA Member # 17731
Treat me good, I'll treat you better. Treat me bad, I'll treat you worse.
alex e is offline   Reply With Quote
Old 07-01-08, 04:09 PM   #2
The pipe method is about 5011 million times easier.
3doghouse is offline   Reply With Quote
Old 07-01-08, 04:17 PM   #3
friel01's Avatar
TLCA# 7618
or
you could try to talk a buddy into trying the slide hammer method, while you frink a few beers, then when that quits being amusing, you can use the pipe method, which is really the only way to go if you already have the center out.
friel01 is offline   Reply With Quote
Old 07-01-08, 04:37 PM   #4
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
I borrowed a slide hammer from the AP store and had no problems. PinHead also suggests running a weld bead on the outer race and the shrinkage will let it fall out.
GL
Ed
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 07-01-08, 08:49 PM   #5
alex e's Avatar
What about heating with a propane torch........just curious. I'm about "this far" from removing the 3d and going for the pipe.....
88 FJ62 Bionic Blue
TLCA Member # 17731
Old 07-01-08, 09:15 PM   #6
Pin_Head's Avatar
Originally Posted by alex e View Post
What about heating with a propane torch.............
You might as well just spit on it.
Your options are the slide hammer (what Toyota uses), a puller, the pipe or weld a bead on the inside of the outer race.
Pin_Head is offline   Reply With Quote
Old 07-02-08, 07:26 AM   #7
GSMTR Chair
Trollhole's Avatar
TLCA# 15077
Pipe takes all of 2 seconds.
Marshall
Upstate Cruisers
Buying a Land Cruiser Guide
73 Fj55 Big Ugly
76 FJ40 ROTW Big Gay 2f Build
75 FJ55 My Build
93 FZJ80 stock everything and staying that way.
Hospedaje | Mobile Phones | Credit Counseling | McDonalds | Loans
