Old 07-01-08, 12:21 AM   #1
'Pops'
island45's Avatar
temp gauge pegged
After my rewire all gauges worked but the temp rises slowly and always pegs on hot. I know it isnt hot because i can hold my hand on the radiator and it pegs so quickly. I tried another sender from an '83 block and it acted the same. There are 2 senders about 6" apart, so it's a bit confusing. It's a '76 2f. I switched the sender at the rear of the block because it seems thats the one that goes to the gauge. What do I try next? Thanks
Some old Ford one ton pickups,'66 fj 45 lpb, '79 fj 55, '66 BSA 441 victor special,BMW r75/5 toaster tank, Ancient one lung engines (1912 Stover...6" bore, 12"stroke, 8 hp at max 300 rpms, 2125 lbs) Never without an old 'cruiser for 23 years. Everything runs, and is mostly original, That's how we roll on Mt. Pickett....
'Rusty ol' floorboards, hot on their feet...' Alan Jackson
island45 is offline   Reply With Quote
Old 07-01-08, 12:54 AM   #2
If you take the temp sender wire and ground it, bet the temp goes to full. Maybe you are getting a partial ground on that circuit. Hey Island, hear about the tall ship that grounded on your island? can,t believe they didn't sink it, not too many places there friendly to ship groundings. One other thought. If there is air trapped in the head then that would cause the temp to look high. Maybe vent the head by disconnecting the heater hose.
Richard
rsbcruiser is offline   Reply With Quote
Old 07-01-08, 10:32 AM   #3
'Pops'
island45's Avatar
Thanks. After work I will try to vent any air from the system. One other clue is that when these gauges were in the '76 donor vehicle, the temp and fuel gauge both stopped working at some point while I owned it. After filling the gas tank in the 45 last night for the first time, it registers just a bit over 1/2 and I know it's full. So the the fuel gauge AND the temp gauge are operating,but wrong... Maybe a common grounding problem. They both worked fine in the '76 when I bought it last January. Also I am using the original tank and sender from the 45 and connected to the later model gauge. And the sailing ship thing. I gotta agree. It's not like it would hit a sand bar.... more like a rock bar. We all refer to our island as 'the rock'.....
Old 07-01-08, 07:47 PM   #4
spotcruiser's Avatar
TLCA# 10016
Hi Gary,
IIRC, one of the two temp sensors in the head is a sender for the gauge and the other is a switch for emissions control. One should be red and the other green (plastic potting around terminal) and I believe the emissions control switch is red. You want the gauge hooked up to the sender, of course. You can pull both of them and test them in boiling water. I think the switch is open above ~130 F. The sender resistance will vary from 90 ohms at 140F to 27 ohms at 212F, per the FSM.
For the fuel gauge issue, the old senders are not compatible with the newer gauges. IIRC, their functions are reversed, resistance-wise. You need to install the later style fuel sender to match the 76 gauge.
Todd.
http://seattlecruiserheads.com/
spotcruiser is offline   Reply With Quote
Old 07-05-08, 07:00 PM   #5
radioridge's Avatar
TLCA# 17613
fj62s have a common problem of the temp gauge and fuel gauge both peging . i dont know if its the same problem but you may gain some insight from a search in the 60 section
radioridge is offline   Reply With Quote
Refinance | Unblock facebook | Cheap Magazines | TV Guide | SEO Friendly Directory
