Old 06-30-08, 03:52 PM   #1
Caddisfly's Avatar
How much Rust Bullet for a frame?
I've spent the last hour or so reading old POR and Rust Bullet posts, but I still don't know how much "paint' is needed to cover a frame. (I did find out that a quart will do the whole underside of a body.)
I'm planning to get some Rust Bullet and the black top coat, but before I order anything, can someone tell me how much I'll need to cover a frame. Will two pints of Rust Bullet do the job?
Thanks.
1978 FJ40
1979 FJ40 (sold)
2004 Tacoma Double-Cab
Caddisfly is offline   Reply With Quote
Old 06-30-08, 04:17 PM   #2
bsmith123's Avatar
rust bullet
2 pints should do it you want to do at least a couple of coats. Also it is good to order it in pints so you don't risk so much in a spill or hardening up on you.
B Smith123
Chaos, panic, & disorder - my work here is done.
The easy way ain't cheap and the cheap way ain't easy!!!
71 FJ frame off build "UGLY BETTY"
33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top on the way!
bsmith123 is offline   Reply With Quote
Old 06-30-08, 05:21 PM   #3
TLCA# 14682
I believe I used 2 quarts on my frame. This was a couple coats. I sprayed it on with a cheap HVLP sprayer
2000 uzj100 '77 fj40 2f/h42/orion; OME 2 1/2 in lift/ 4wdb '64 fj45swb
meat is offline   Reply With Quote
Old 06-30-08, 06:51 PM   #4
I just ordered a quart of Por-15 ecapsulator and a quart of por -15 chasis for top coat. I plan to hvlp it next week i can let you know for sure then. Dont know how big of a hurry you are in
4x4 Station Wagon is offline   Reply With Quote
Old 07-01-08, 05:37 AM   #5
M5driver's Avatar
Thanks.
Superfly - 2 pints (one quart) should do it. Get 3 pints as insurance, or in case you want to spray 3 coats. To be really sure, if you are going to use brushes to coat up the boxed sections, get 4 pints since it will take about a pint to do 2 coats on the interior sections. If you do all that, you won't need the Black Shell - you can just use a good quality chassis black paint over the RB (within 48 hours to topcoat without sanding). Alternatively, you can use the silver bullet for the first (and second) coat(s), then top coat with RB Black Shell for the final rust proofing coat.
Make sure there is no loose gunk or rust and no grease or oil on it; DO NOT attempt to thin the RB with water contaminated thinner, even if you don't know the thinner is contaminated. Ask me how I know
1978 FJ40, "The Blue Mule", 217,000 miles
1980 Maule M5-235C, "The Blue Beast", 1404 hrs TTAF&E - FJ40 with wings
1982 Mercedes 300D Turbo, "Ol' Red", 380,000 miles
1953 Spousal unit, "The Wife", lifetime warranty, definite keeper (and firmly attached to all of the above)
KA3JWW, but I don't have my rig right now
M5driver is offline   Reply With Quote
Old 07-01-08, 06:25 AM   #6
Caddisfly's Avatar
I'm not in a hurry -- I'm getting some mounts and other stuff taken care of next week, then I plan to use Rust Bullet or POR.
Based on everyone's responses, I'll order two pints (in separate containers).
Thanks again for the help.
(M5Driver, I laughed when I saw your "Superfly" reference. The title character and I have nothing in common, however. I'm addicted to fishing, which explains the nickname "caddisfly"; Superfly was addicted to ... well ... other pursuits.)
1978 FJ40
1979 FJ40 (sold)
Old 07-01-08, 07:12 AM   #7
KY Longhunter's Avatar
Rust Bullet highjack
I just ordered a quart of Rust Bullet yesterday from Summitt Racing (free shipping!).
I confirmed by calling Rust Bullet that the Black Shell is not necessary, overkill IMO. I'm going to use some black rustoleum or similar product.
Just one question to other posters...how do you thin RB to spray thru a sprayer?
BTW...I've never sprayed anything. Admittedly I'm a novice.
1981 FJ40 - Build Photo Album
http://picasaweb.google.com/ARios2539/1981FJ40
2005 Sequoia Limited 4x4
An intelligent man is sometimes forced to be drunk to spend time with fools. -- For Whom the Bell Tolls ~ Ernest Hemingway
KY Longhunter is offline   Reply With Quote
Old 07-01-08, 08:29 AM   #8
M5driver's Avatar
Just pullin' yer chain. At least you're not "tsetse fly"
Old 07-01-08, 08:32 AM   #9
M5driver's Avatar
If you get the automotive version (silver label) you don't need to thin it - it's ready to spray. If you get the standard version (gold label), you need to thin it with MEK (or toluene or xylene) to spray - about 8% seems to work very well. Make sure the thinner is clean... NO water! Really!
Old 07-01-08, 02:47 PM   #10
tlc_4play's Avatar
When I Rust Bulleted my chassis I used 1 Ltr of the Gold Label - this allowed me to apply 2 coats.
I used Xylene to thin and clean the equipment, I thinned the RB by about 15% this was absolutely essential as it was much too thick to spray.
I cant remember pints and quarts anymore, but I think 1 ltr is about 1 qrt
1999 - FZJ105
1979 - BJ-FJ40
tlc_4play is online now   Reply With Quote
Old 07-01-08, 02:53 PM   #11
I brushed mine on and used about 1.5 quarts
avgas is offline   Reply With Quote
Magazine Subscriptions | Loans | Personal Loans | Mortgage Calculator | Loans
