Old 06-29-08, 10:07 PM   #1
yotawheeler's Avatar
truck wouldnt start. balast resistor?
ok...so i went out to play a bit in a local quarry and came down off a rock pile and the truck was dead, made sure it wasnt out of gas and it still wouldnt start, turn but no fire. some guys came by who were more mechanically inclined then me and said it was the balast resister. once the bypassed it the truck would start but not idle, as soon as i was off the key it died. i made it home by keeping the key turned (home was only about 5k) but im not sure what they did to bypass the resister...anybody have any ideas?
in my driveway....
'74 FJ40- disc brakes, saginaw,8274. SM420 sitten in the shop just waiting
'78 FJ45 project rig
x2 '81 BJ42
'86 HJ60
yotawheeler is offline   Reply With Quote
Old 06-29-08, 11:06 PM   #2
You got me.
My 40 has no ballast resistor. It has a coil with an internal resistor
It is my understanding 40's didnt have ballast resistor as the coil
has the internal resistor
Are you saying you had to hold key so the starter was turning the
entire way home?
1970 fj40 f engine 3sp w/floor shift 2.5 procomp lift 32" AT tires, Warn Bellvue winch. Evolution Blog http://dirtsquirtfj40.blogspot.com/
Dirtsquirt is offline   Reply With Quote
Old 06-30-08, 12:10 AM   #3
mmmm well yea i guess it would have been, the key was turned in the start position, if i let off of it the engine would die. this was just an extremly temp thing to get me home and out of the quarry that i was in. the truck has not been driven since i got it home...i need to get it sorted out before i drive it any more
in my driveway....
x2 '81 BJ42
'86 HJ60
Old 06-30-08, 05:19 AM   #4
bsmith123's Avatar
ballast
you have two routes for wiring to your coil + side one through the ballast resistor, another that applies a full 12 volts during start
you were using the start pos and bypassing the BR --sounds like they didn't do anything
to make it run ---temp run a wire from your batt to the + side of the coil but fix it as soon as you can
B Smith123
Chaos, panic, & disorder - my work here is done.
The easy way ain't cheap and the cheap way ain't easy!!!
71 FJ frame off build "UGLY BETTY"
33 in BFGs, 4 inch HFS lift, Durabak lined tub, and a soft top in a box! Now sportin a 2F and 4 speed
bsmith123 is offline   Reply With Quote
Old 06-30-08, 07:46 AM   #5
Hmm
I couldnt find a diagram for your specific year online. but I did find one for an earlier year.
http://www.ih8mud.com/tech/72fj40-wire/71fj40_wire.gif
according to this you have 1 wire to the positive. (excluding ACC
like Pertronix or Tach.)
I am gonna say it sounds to me like your ignition switch has taken "a
turn for the worse".
A test light or a vom should easily diagnose this. If it is consistent
Turn the key to run position. ie one click to the right from key removal position
Check for 12v at the IG (ignition) terminal on the back of the
Key switch, Start Switch etc. the Print calls it the Ignition Switch.
Good luck
Old 06-30-08, 09:42 AM   #6
Pin_Head's Avatar
Your problem is consistent with a bad ballast resistor. The starter motor has a wire to bypass this resistor during starting so that full voltage is applied to the coil when the battery voltage drops due to the starter motor turning.
Get a new one. They are a couple of dollars at NAPA and they are generic.
As noted above, you can temporarily bypass this resistor (so you don't burn out your starter motor) by moving the hot wire from the ballast resistor to the coil + post. If you run it like this continuously, the coil will overheat.
Toyota used ballast resistors on cruisers throughout the 70s.
Pin_Head is online now   Reply With Quote
Old 06-30-08, 10:02 AM   #7
Cruiser Curmudgeon
FJ40Jim's Avatar
TLCA# 1914
BR was factory spec on 73-77 USA trucks.
78-80 models w/ elec ignition got a resistor wire in lieu of an ceramic resistor.
On a 74, power for the ignition is supplied by a dedicated fuse. So it sould be as simple as a bad fuse.
Thanks,
Jim C.
TLC Performance
Underhood Janitor, cleaning up other people's since 1988.
FJ40Jim is offline   Reply With Quote
Old 06-30-08, 07:14 PM   #8
wicked. thanks for the help guys....iv been kind of looking at it trying to figure out what the guy did and im still not 100% sure but ill get the BR tomorrow. the local parts guy is into old school chevs so he is pretty good about helping me out
in my driveway....
x2 '81 BJ42
'86 HJ60
Old 07-01-08, 03:41 AM   #9
tlc_4play's Avatar
Did some research
A ballast resistor is only required if the resistance of the coil primary is less than 2.5 ohms.
example; my Pertronix Flamethrower 12V coil has a primary resistance of 1.5 ohms, therefore the installation of at least a 1.0 ohm ballast resistor is recommended to limit the current and prevent overheating the coil when doing slow 4wheeling (+/-1500rpm)
1999 - FZJ105
1979 - BJ-FJ40
tlc_4play is offline   Reply With Quote
Old 07-01-08, 07:30 PM   #10
got 'er going...thanks guys!
in my driveway....
x2 '81 BJ42
'86 HJ60
Credit Card Debt Consolidation | Car Credit | Myspace Layouts | Money | Credit Cards
