Real time issue...Max Tire pressure??
With the price of fuel, I'd like to run my tires at max pressure when I'm on the highway..I air down to 8-12 psi when I'm offroad, and used to normally run at 35 psi on the road...I have a longer highw driving trip planned tomorrow and would like to go higher...
I'm running 33 X 9.5 X 15 BFG Mud Terrains, which say max loading of 2510 lbs at 50 psi cold...should I/can I take them up to 50 psi for highway driving?? __________________ Zekester SW Ontario, Canada 12/79 BJ40, 3B, Gozzard F/G body, Herculinered, 3" lift, SS snorkle M101 Expedition Trailer I/P 1997 BMW 328is 1957 Porsche 356 replica |
do the old chalk test. Air them up to where you think is good. Put nice wide line of chalk across the tread; maybe 3" or so. Drive a mile or so at highway speed Best performed on less traveled section of road with a wide shoulder. Look at the wear pattern. If it's even your close. Repeat until the contact patch does not extend all the way across the tread. Note the last pressure. Repeat, but air down until the wear pattern is on uneven: outside edges show more wear.
In the end you will have a decent operating range (maybe 5 to 10 psi). Then it's all about at what point in the range of pressures is the sweet spot. What pressure exhibits the best handling? Oh, it's critical to load up your cruiser as if the trip was today. It is not uncommon for the front and rear tires to be aired to different pressures. Best of luck! Be careful and enjoy the trip. __________________ 73' FJ40 www.4x4Boyz.com AlohaFJCruiser www.oahujeepers,com (good guys even if their taste in name doesn't necessarily reflect it! LoL) www.hawaii4x4association.org (promoting legal, responsible 4wheeling across the Hawaiian Islands) |
refer to Hunter S Thompson - Fear and Loathing in Las Vegas...
__________________ TJS -- 1978 FJ-40 1974 FJ-55 w/ 3FE CO/WY - Horsetooth 4 Wheelers Cruiser Club <<CLICK HERE>> for my Tech Threads |
#5 | |
HElp me out here. I'm not familiar with the reference.
Me and my Big Wheel
why not have a blow out and roll your vehicle and jepordize the safety of others on the road to save 3 bucks when you fill up.
makes sense to me __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#8 | |
....? __________________ 74' FJ40 Freeborn Red, 114kmi, 31x9.50 ssTSLs on stock steelies, stock, except non USA Dist. Awesome. |
Heh heh heh, there is a great account in the book of him pumping up the tires in a rental car to 90 PSI. The gas station attendant won't do it. HST is telling him they are experimental tires... Very funny read!
#10 | |
By inflating a tire to maximum rated pressure on a vehicle that doesn't need it, you may improve gas mileage, but you will also wear out the tire tread center faster, and you decrease the tire's traction capability by reducing it's footprint right off the bat (that's how your gas mileage improves). Maybe that's fine if you're rolling down a straight, smooth, dry, uncrowded highway, but when conditions become wet or icy, overinflation results in poorer steering and handling, and you become a hazard. These are not minor points. You not only are a risk when you overinflate, but you can end up cutting your tire life in half. It's doubtful that the slight savings at the gas pump will make up for these issues. (I, too, recommend the chalk method). ![]() Incidentally, I also have BFG Mudders in 9.5x33x15, and since they don't make them any more, I wouldn't do anything to make them wear out faster! __________________ 9/70 FJ40 +Rollbar 9/64 FJ45 (L) P-B with restored wiring 4/84 Toy 4x4 Mini PU "The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton Last edited by IDave; 06-29-08 at 11:21 PM. |
#11 |
thanks for the advice....as far as the blow out line...I'm trying not to over inflate, that was the whole point in this...If I wanted to "have a blowout and be a hazard"...I would have just went to the max 50 psi and been done with it...
at 32, which i was running on the highway, I was getting uneven wear...yes on the now unavailable mudders.... I'll go the chalk method... __________________ Zekester SW Ontario, Canada 12/79 BJ40, 3B, Gozzard F/G body, Herculinered, 3" lift, SS snorkle M101 Expedition Trailer I/P 1997 BMW 328is 1957 Porsche 356 replica |
#12 |
I realize you understand. I was responding to Ziffdaddy's "?"
How was the wear uneven? Edges or center? (Just curious) __________________ 9/70 FJ40 +Rollbar 9/64 FJ45 (L) P-B with restored wiring 4/84 Toy 4x4 Mini PU "The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton |
#13 | |
Thanks for the clarifacation Pablo. I'll look it up! iDave the chart is great! A picture is worth a thousand (er at least ac ouple paragraphs) words. Thanks __________________ 73' FJ40 www.4x4Boyz.com AlohaFJCruiser www.oahujeepers,com (good guys even if their taste in name doesn't necessarily reflect it! LoL) www.hawaii4x4association.org (promoting legal, responsible 4wheeling across the Hawaiian Islands) |
#14 | |
I did the chalk method, ended up around 40 psi being the best, I ran about 500 miles in two days, some on the 400 series highways, no problems, cept the sunburn waiting at the border, bikini top up on the way back : ) __________________ Zekester SW Ontario, Canada 12/79 BJ40, 3B, Gozzard F/G body, Herculinered, 3" lift, SS snorkle M101 Expedition Trailer I/P 1997 BMW 328is 1957 Porsche 356 replica Last edited by Zekester; 07-03-08 at 05:05 PM. Reason: more detail |
#15 |
Thanks for the followup!
Mobile Phone | Online Loans | Web Advertising | Power Rangers | Online Advertising |
