Old 06-28-08, 02:33 PM   #1
Melloj123's Avatar
New Lift Installed Hell Creek 2.5"
Just put a new lift and shackles on the cruiser a couple weeks ago and getting around to posting some photos. Removal of the old was pretty easy and the new Hell Creek 2.5" kit went on smoothly. The shackles are HFS 1.5" over stock.
Have a slight vibration going from 2 to 3rd gear. I put some shims in the front to try to see if it helped and it seemed to a little, but annoying vibration is still there. Did a search and checked the U Joints, they seem to be fine, no movement at all in the drive shaft.....What other suggestions...
Didn't think the drive shaft angle would have moved that much with such a small lift. Enjoy the pics and I welcome your comments.
1970 FJ 40, Dune Beige
1977 FJ 40, Olive Brown, 35K original miles, 2.5" Hell Creek, 33 x9.5" BFG/AT
1978 FJ 40, Mustard
1985 FJ 60
Melloj123 is online now   Reply With Quote
Old 06-28-08, 02:34 PM   #2
Melloj123's Avatar
a couple more.
1978 FJ 40, Mustard
1985 FJ 60
Old 06-28-08, 02:53 PM   #3
Are you sure those aren't 4" springs? Did you take any measurements before/after?
I have Hell Creek 2.5's on mine with 33 x 10.5's, and yours looks quite a bit taller than mine.
3doghouse is offline   Reply With Quote
Old 06-28-08, 03:09 PM   #4
Melloj123's Avatar
They are 2.5"...My dad has the same kit and we are right at the same height. Maybe looks tall because my tires are small.....31x10.5....It really hasn't had time to settle yet either...
1978 FJ 40, Mustard
1985 FJ 60
Old 06-28-08, 03:16 PM   #5
well he did say he has 1.5 over stock shackels would that put it at 4" ?
1975 FJ-40
303garage is offline   Reply With Quote
Old 06-28-08, 03:30 PM   #6
I thought it looks tall myself ,I just ordered the 4" lift from hell creek and thought s**t mabe thats
too much , But I will be running 35"s. Hopefully just right. by the way I like the cruiser.
1975 FJ-40
Old 06-28-08, 03:35 PM   #7
CottonLand Cruisers
Bodean's Avatar
TLCA# 3164
Go somewhere and flex it out good. Looks good.
Later,
Jeff
CottonLand Cruisers
Whitetrash of the Elwood Chapter
78 FJ40
TLCA #3164
USAF - POL 1987 - ? http://www.youtube.com/watch?v=lxVEqVDUuJE
"I reckon you gonna have to come up here and get me. I done messed around and got drunk as a piss aint"
Bodean is offline   Reply With Quote
Old 06-28-08, 04:28 PM   #8
vk7ybi's Avatar
No.. Think of the spring as a lever, with mecanical advantage ratios.. The centre pin that locates the axle isnt in the centre.. IIRC, its about 45/55 with the shorter side being the fixed side.. Therefore lengthening the shackle by 1.5" should cause aditional lift of around 1.5x0.45, or 0.675 inches? So a total lift of 3.175 inches?
'78 FJ40 Soft Top, 35x10.5 Silverstone MT-117s, 8274, Lokka Rear - RD02 Front, 2.5in lift, H41, 4.11, LPG.
'78 FJ40 Hard Top, 33x10.5 Silverstone MT-117s, 8274, Lokka Rear - RD02 Front, H41, 4.11, RDB.
'81 FJ40 Hard Top, 33x12.5 BFG MT's, 2.5in lift, H41, 4.11, 253 Holden V8, Power steer.
vk7ybi is online now   Reply With Quote
Old 06-28-08, 05:03 PM   #9
ok, i see what you mean . makes perfect sense ..thanks greg.
1975 FJ-40
Old 06-28-08, 07:42 PM   #10
OK,
Your sig says 33... and I missed the olive part, so I thought that's what I was looking at. If the pics are of 31's, that makes much more sense!
Old 06-29-08, 03:18 AM   #11
Ziffdaddy's Avatar
TLCA# 18034
Geeeeez....you could eat off the under side of the wheel wells....
74' FJ40 Freeborn Red, 114kmi, 31x9.50 ssTSLs on stock steelies, stock, except non USA Dist. Awesome.
Ziffdaddy is offline   Reply With Quote
Old 06-29-08, 10:43 AM   #12
Fast Eddy's Avatar
TLCA# 18155
Olive Green, not Olive Brown. 653 is a 6** like all the other greens. Rustic Green is 621. John Deere Green is 681.
トヨタさん、ありがとうございました。
My '78 FJ40 - '73 and '78 FJ40 parts FS - WTB:Olive (653) Bib and Windshield frame
Originally Posted by OZCAL
Woke up the next day with a partially detached retina, wrapped in a sheet on a wooden floor, in a storeroom upstairs from a barbershop.
Fast Eddy is online now   Reply With Quote
Old 06-29-08, 12:11 PM   #13
TLCA# 6453
Man, that's a clean truck!!! Cool color too.
'75 FJ40 mostly stock....yeah right!
www.employees.org/~dirttrak
mustardfj40 is online now   Reply With Quote
Old 06-29-08, 04:38 PM   #14
Melloj123's Avatar
Thanks for the kind comments guys. No one chimed in on my vibration problem. Went out and drove it some more today. Vibration between 2 and 3rd gear, and in fourth when going about 50mph. Any help ???
1978 FJ 40, Mustard
1985 FJ 60
Old 06-29-08, 08:42 PM   #15
CottonLand Cruisers
Bodean's Avatar
TLCA# 3164
What degree shims did you use?
Jeff
CottonLand Cruisers
78 FJ40
TLCA #3164
Old 06-29-08, 09:22 PM   #16
i got a hell creek 4 inch on mine and at first i had vibration goin into 3rd then i shimmed the rear and it took care of the problem
rayho91 is offline   Reply With Quote
Old 06-30-08, 05:52 AM   #17
Melloj123's Avatar
Bodean, i put 4* shims on the front.....Do i need to do the rear as well??
1978 FJ 40, Mustard
1985 FJ 60
Old 06-30-08, 05:57 AM   #18
tlc_4play's Avatar
Looks Cool
I've put 4" Heystee Parabolics on my 40 - I think I'll need a ladder to get in
Based on what Ive read here - I put 4deg shims in the front for castor correction and 2.5 deg shims on the back, purely to improve the propshaft angle.
1999 - FZJ105
1979 - BJ-FJ40
tlc_4play is offline   Reply With Quote
Old 06-30-08, 06:53 AM   #19
total rice
dgangle's Avatar
TLCA# 10793
Originally Posted by Melloj123 View Post
... No one chimed in on my vibration problem. Went out and drove it some more today. Vibration between 2 and 3rd gear, and in fourth when going about 50mph. Any help ???
I would check 3 things on the read driveshaft assuming it didn't make this vibration before the lift and it's doing it in 2WD Hi, not 4WD.
A. make sure the rear DS is "in phase"
B. see if there is any noticeable up/down play in the rear driveshaft slip joint
C. remove the rear DS and measure the angles of the two mounting surfaces (parking brake drum and rear pinion flange). These need to be the same or very close. Maybe the lift changed this. If they are off by more than say 2 degrees use shims to correct.
How does it ride with no top and vertical shackle angles? What size tires are you saving up for?
1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000
2007 4 Runner SR5 4WD - stone stock daily driver
2007 Avalon - free company Grandpa car
TLCA#10793
My ROTW: http://tinyurl.com/2mfwfw
Originally Posted by C W McCall View Post
So we crashed the gate doin' 98, I says let them truckers roll, Ten-Four.
dgangle is online now   Reply With Quote
Old 06-30-08, 06:56 AM   #20
GreenBomber's Avatar
Well that cruiser looks awesome. Shackle angles are at like 90*, hope they settle down some!!
1966 GREEN FJ-40
SOA, Stock F Motor. - Runs, stops and leaks.
1996 Toyota 4Runner - 35's, locked, armored
2003 Toyota Tundra - Stock
1996 Toyota Camry - Stock
GreenBomber is offline   Reply With Quote
Old 06-30-08, 08:41 AM   #21
77TLCFJ40's Avatar
TLCA# 13533
Flex that thing and they will settle just right. Ask me how I know...
Lash
CottonLand Cruisers Treasurer
TLCA: 13533
Madison, MS
02 UZJ100 Daily Driver De-blinged Emblems
77 FJ40 "GunRunner": York/Mudrak OBA, Aussie, 8274, Mini PS, Hell Creek Lift, 94" WB, 35x12.50 Hankook MTs, MAF U-Bolt Flips, F-250 Towers, MetalTech Cage, Choctaw Sliders, 8" Tuffy, Tiburon Seats... and a great group of friends who made it possible!
78 Hilux Trailer
"... slowly I'm becoming one with the MUD." -- Jars of Clay
77TLCFJ40 is offline   Reply With Quote
Old 06-30-08, 03:54 PM   #22
Melloj123's Avatar
Dgangle, i will check the drive shaft angle, you said to remove the drive shaft, where do you exactly measure the angle on the pinion flange and the parking brake. Also, help explain "in phase" to me.
Tires, i would love to have some tall, skinnies, 33x9.5 . I have some stock steel rims to put them onto one day...
Yeah the shackle angle is vertical. I spoke with Tom at HC and he said that is how they should be. They will settle into position with some usage.
1978 FJ 40, Mustard
1985 FJ 60
Old 06-30-08, 07:11 PM   #23
Noaccount Webwheeler
Degnol's Avatar
TLCA# 14529
I used a magnetic angle finder on the pinion flange and the parking drum. You need to be within 1-3*. Those longer shackles have rotated your pinion up so you need to rotate it back down with shims or use a double cardigan(Cardan) shaft. I bought the weld-on shims from Roger.
GL!
Ed
P.S. Those rear shackles are fugly.............................
There is nothing so depraved as a man in the depths of an ether binge
'66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Degnol is offline   Reply With Quote
Old 07-01-08, 04:28 PM   #24
Melloj123's Avatar
Thanks Ed, i will measure the angle and go from there.
1978 FJ 40, Mustard
1985 FJ 60
Old 07-01-08, 04:32 PM   #25
Degnol's Avatar
TLCA# 14529
That Mustard truck is very gorgeous!!!!
Old 07-01-08, 05:11 PM   #26
pbgbottle's Avatar
TLCA# 14678
you could also try pumping some grease into the slip joint part of the drive shaft . sometimes this helps .
after the lift the driveshaft has had to lenghten some. but i too would check the pinion angle
Jake S.
FJ40,small block ,sm465 ,spring over ,cut-N-turn,shackle reversal, 38.5 superswampers, 4 wheel disc brakes, OBA=CO2 ,Warn 8274
...ROTW:PBGBOTTLE
.... ...Cardomain Pics
... EPC anybody
pbgbottle is offline   Reply With Quote
Old 07-01-08, 05:27 PM   #27
Degnol's Avatar
TLCA# 14529
Jeremy, you want the yokes in the same plane, not off by a spline or two. HTH........figure 4.11
Ed
