Help with MSD wiring on TBI
I am trying to wire in an MSD 6T (p/n 6446) into the TBI in my '76. I am apparently missing something huge because I cannot figure the wiring out. My setup involves:
'78 distributor (modified to pull out advance - per Downey instructions and TBI thread) Standard barrel type coil without amplifier MSD 6T I have tried emailing MSD but haven't got an answer. I am using the GM TBI from an Astro van. I have attached the GM wiring diagram that matches what I have. I am also attaching the MSD instructions. Can someone tune me in to what goes where? I know the heavy red and heavy black go to the battery. The black should go to the - side of the coil and orange to the + side of the coil. The red and white should connect to the P/u in the distributor. How do I tie in the white, purple, tan, and black to have it talk to the computer? __________________ Lloyd Kortbeek '76 FJ 40 Calgary, AB |
Apparently working on your cruiser late at night is not the ideal time to try and figure stuff out. After not getting a response from MSD for a few days on my query, I broke down and picked up the phone. The tech support guy at MSD was very good and patient. It took some time but he was finally able to explain that I could not replace the GM ignition module as it talks with the computer and the MSD does not. It just replaces the coil part. I need to wire the ignition the way GM says and then use the 'dual connector' coil wiring diagram to put the MSD in place of the GM coil ONLY.
. It means I have to use the GM ignition module still, so I think I will do the GM distributor switch and give the module a good place to live.
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/228042-help-msd-wiring-tbi.html
| tbi wiring - forum post summary | BoardReader | This thread | Refback | 08-21-08 03:41 PM | |
Online MBA Degree | Credit Cards | Online Advertising | Fast Loans | Mobile Phone |
