Old 06-18-08, 09:01 PM   #1
FJ40 stalling, fuel pump problem?
I have a 1978 FJ40 that idles and runs great for a short distance, then it stalls out. If you let it sit for a few minutes, it will start up again and only run for short time until it stalls out again. I have checked the tank for anything in the tank, changed the fuel filter. Could it be the fuel pump? Or could it possibly be a vent problem? Any help would be great
AJSFJ40 is offline   Reply With Quote
Old 06-18-08, 10:05 PM   #2
Dog is my co-pilot.
Josie'sLandCruiser's Avatar
TLCA# 6446
Hi All:
Stock mechanical fuel pump or aftermarket electric fuel pump?
Are you using the stock-type closed cylinder fuel filters or the generic aftermarket clear plastic ones? Any debris at all in the fuel filter?
Have you drained and flushed-up the fuel tank?
Sorry, no easy answers to a question like this.
Good luck!
Alan
www.seattlecruiserheads.com
Josie'sLandCruiser is offline   Reply With Quote
Old 06-18-08, 10:47 PM   #3
Ramblin Wreck
CruisinGA's Avatar
try removing the gas cap
Bailey Quintrell
'74 FJ40--37 Irocks-32 Bolt 'Locks-SM420-ARB-XD9000i-FJ60 PS-MetalTech Cage
'93 FZJ80-DD-Part Time 4wd-locked-5" lifted-snorkel-bullbar-315 AT's
'97 FZJ80
'98 UZJ100-OEM RR locker
ΣΧ
CruisinGA is offline   Reply With Quote
Old 06-18-08, 11:01 PM   #4
Feel your pain
Been there done that.
I agree on the gas cap. improper desmogging can lead to no tank
vent.
In the end I replaced my fuel pump and Voila!
1970 fj40 f engine 3sp w/floor shift 2.5 procomp lift 32" AT tires, Warn Bellvue winch. Evolution Blog http://dirtsquirtfj40.blogspot.com/
Dirtsquirt is online now   Reply With Quote
Old 06-19-08, 07:18 AM   #5
springfield user
brian's Avatar
TLCA# 6955
when it dies.
if you try to refire right after it stalls, what happens?
does it try to light or just turn over with no effort to catch?
it's only metal, we can out think it.
77-fj40 20th anniversary edition
87-fj60 216K mile DDer
93-fzj80 mall crawler
toyota material distribution center. your source for Factory Service Manuals.
they're alot cheaper than you think.
1-800-622-2033
brian is offline   Reply With Quote
Old 06-19-08, 08:09 AM   #6
When I initially start it, it runs great. But after driving about a half mile it dies. I can start it back up, but it will not run very long. Really acts like it's starved for fuel. I am going to try the gas cap removal today and see if it's a venting problem. I have had the carb rebuilt and desmogged. Thanks for the help
Old 06-19-08, 08:59 AM   #7
Texx's Avatar
Sure the fuel cut solenoid has power and is working?
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 under resto..mine now! ! 03 Tacoma TRD SR5, Suzuki DR350
Born to raise Hell! Right after my nap.
Texx is offline   Reply With Quote
Old 06-19-08, 03:31 PM   #8
TLCA# 16795
Do you have your input and return line mixed up? Run the engine and look at the fuel level through the sight glass and see if it goes down while you're revving it up.
ducktapeguy is offline   Reply With Quote
Old 06-19-08, 09:36 PM   #9
Ramblin Wreck
CruisinGA's Avatar
I've had this issue twice.
1st time- bad gas cap
2nd time- failing fuel pump
Most vacuum guages can test fuel pump pressure as well. A good tool to have and very useful in this particular instance.
Bailey Quintrell
'97 FZJ80
ΣΧ
Old 06-19-08, 10:36 PM   #10
TLCA# n/a
I second Texx...even North of the Red River.
74fjsemistock is offline   Reply With Quote
Old 06-25-08, 05:11 PM   #11
I have tried removing the gas cap and it still stalls. When it does quit, I pop the hood and checked the site glass on the carb, shows no gas. I let it sit for about 5 minutes and start it and it will finally start and gas will slowly fill about half way up on site glass. Then I can go a short distance and it quits again with the sight glass being empty. I have remplaced the fuel filter twice, drained the gas from the tank, checked in the top of the tank and it dosen't look like there is anything in my tank. Can I mechanical fuel pump act up in this manor? After sitting for several hours, it will start and run great and then just stall. The motor is stock, the carb has been completely rebuilt by Jim at TLC. Let me know what you guys think.
Old 06-25-08, 05:28 PM   #12
35inchoverdrive's Avatar
TLCA# 12330
There was a local guy here with a 40 that had a similar problem. He had a small hole in the bladder of the fuel pump, and once it warmed up, it would leak, and fail to pump. Once his rig cooled back down, it would start and run again. If the sight glass is empty, you've ruled out the fuel filter, and you've checked the tank for obstructions, it sounds like the pump is the culprit to me.
Columbia, SC
71 FJ40 little Swampers, cheap lockers, big winch
72 FJ40 stocker with PTO winch
85 FJ60 lawn ornament
87 FJ60 w/ H55F
35inchoverdrive is offline   Reply With Quote
Old 08-20-08, 09:37 PM   #13
I have tried the fuel cap, new fuel pump, drained the fuel tank, fuel filter, and cannot for the life of me get this problem fixed. It will run forever when it just sits and idles, but when I drive it a couple of miles it stalls out. Any other suggestions fellas? Thanks
Old 08-20-08, 09:57 PM   #14
Hobbs's Avatar
Perform a fuel pressure AND volume test on it. Toyota used to provide pressure and volume spec's in the service manual....
--- DAN ---
1978 FJ40
Hobbs is offline   Reply With Quote
Old 08-20-08, 10:10 PM   #15
Man that sucks
Based on you posts.. you are having a fuel delivery issue.
The sight glass drops.
Could be:
1 Fuel lines from the tank to the fuel pump. Swollen or pinched
or partially plugged. Remove inlet to the pump and back blow.
remove the gas cap regulate shop air to 15psi and try a back blow
if nothing else this may dislodge chips or rust particles and move em back to the tank.
2 Disconnect the fuel pump outlet and the other end at the carb.
Blow this line also from the carb end.
4 replace the entire fuel line from the the tank to the pump. wouldnt hurt. the old one is 30yrs old.
5 not having a stock carb.. i cant attest to how hard it is to remove the fuel bowl and blow out fuel passage to the float.
6 other than that you have done everything I woulda done
I feel your pain . good luck
Refinance | Old Navy Coupon | Remortgage | Expired Pr Domains | Mortgages
