carb/intake spacer? Throttle linkage pics?
Have a 72 fj40 with original intake manifold but PO had a rochester carb on it. Just installed a 75 Aisin cali-spec carb and the throttle linkage hits the top of the intake manifold when i manually push the linkage to rev it up. (1)Wondering if there is a spacer to raise the carb up i dont know about. (2)Also, i need pics of the throttle linkage so i can get the gas pedal hooked up. (3)Also, what is the orientation of the carb on the intake, throttle linkage towards the firewall or towards the front of vehicle??(4)Lastly, the tube coming off the carb in the pic(EGR?) is taped off until i get a cap since i have no smog equipment, wondering if there is supposed to be fuel that collects at end of that pipe.
__________________ '72 FJ40, F, MAF Header, 75 Aisin carb, rear spring flip, SOA, 35" BFG MT's, GM power steering, Sidekick rear seat, prelude front seats, reinforced factory tire carrier, custom bumpers and rockers, etc. Last edited by Benjitis1; 06-15-08 at 05:37 PM. |
what kind of linkage do you have now? 72 should have a throttle cable assembly and the 75 would have had a rod linkage assembly. The 75 would have had a carb issolator which is aprox 1" thick
The fuel window of the carb faces forward. not sure what tube your referring to, maybe a pic? __________________ those that fail to prepare are preparing to fail....Benjamin Franklin 1965 FJ45 LWB 2nd owner, 2F, 4speed, sprung over, 35"BFG Mud terrains 1965/67 FJ45 SWB combining 2 into 1 under construction 1970 FJ55 all stock 1980 FJ40 all stock, factory air and power steering, 82,000 miles |
Anyone got a carb issolator for sale?
__________________ '72 FJ40, F, MAF Header, 75 Aisin carb, rear spring flip, SOA, 35" BFG MT's, GM power steering, Sidekick rear seat, prelude front seats, reinforced factory tire carrier, custom bumpers and rockers, etc. |
Anyone?
Ask in the parts-wanted section. Someone will chime in...
__________________ トヨタさん、ありがとうございました。 My '78 FJ40 - '73 and '78 FJ40 parts FS - WTB:Olive (653) Bib and Windshield frame -- Originally Posted by OZCAL Woke up the next day with a partially detached retina, wrapped in a sheet on a wooden floor, in a storeroom upstairs from a barbershop. |
Noaccount Webwheeler
I have one of the bakelite spacers that has the PCV port on it. Need a pic? Ed __________________ There is nothing so depraved as a man in the depths of an ether binge '66FJ40, Fresh 2F, H42/Orion(By Poser...LCR4WD), ARB Front/rear(By Poser...LCR4WD), MetalTech Cage installed by Poser, Screw-ups fixed(by Poser) 4WDB Corvette Master, Mini Truck PS, 3.5" Lift, Warn 8274, 33s on stockers
Ordered a carb isolator from Mark, thanks for the help.
Vegas Hotel | Article directory | Loan | Credit Card | Problem Mortgage |
