Old 06-09-08, 10:26 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
I need a little Advice :)
Allright then, I have a 75 FJ40 with the stock F2 or whatever, and it's got hedders on it, original cam etc... yadda yadda nothing special...
I bought a Webber 2V from one of mud's members and for $75 bucks I got a great deal. The carb is fairly new, but the guy used it like a trooper and there was sand in every orifice in the carb.
So I am rebuilding this carb and I CANNOT find a kit or carb # to get a PROPER kit for it :( :(
Got one kit from Car Quest and there are only 5 Damn pieces in it!
2 gaskets , one diaphragm, one needle and seat set adn a little o-ring...
WTHF is that all about? I need the 3 fingered diaphragm also but nobody in this damn town even know's what the hell a friggin Webber is... Should I got buy a ford PINTO carb kit or go to the Local German car shop?
There are some #'s on this but nothing any of the fuctards I called could get anything from them. :(
So folks, What is a guy to do?
Also the Secondary Venturi set screw has the blade fully closed, shouldn't there be some secondary exposed to assist the A/F screw in metering the Idle controll?
I am not carb retarded, but on a Webber I can be considered so for this job.
Thanks!
FE
FJ-40Original is offline   Reply With Quote
Old 06-09-08, 11:23 PM   #2 (permalink)
rsbcruiser's Avatar
Maybe man-a-fre can help you . They carry the Webber stuff. The secondaries, I think, are supposed to act as you described. Webbers are set up progressive. It is important that you go through the set up procedure described by Webber. Have you seen the FAQ on this subject? load of info there.
Originally Posted by Atticus: rsbcruiser, poet laureate of the truly inane.
rsbcruiser is offline   Reply With Quote
Old 06-10-08, 05:02 AM   #3 (permalink)
andrewfarmer's Avatar
why do you want to put the Weber on it?
My ROTW thread...
andrewfarmer is offline   Reply With Quote
Old 06-10-08, 07:34 AM   #4 (permalink)
Texx's Avatar
Search weber carb tuning thread, there's someone on here who's pretty knowledgeable about it.
world's cleanest 89 FJ-62, and a few parts... 85 xcab hilux 4x4 resto'ed, 67 XKE, 1500 Vulcan, 80 Fj40 restored SOLD:( 03 Tacoma TRD SR5, Suzuki DR350 Sold :(
Texx is online now   Reply With Quote
Old 06-10-08, 08:31 AM   #5 (permalink)
Why do I want to go webber?
Well, the Original carb is gone and there was a POS GM 2bbl on it that was absolute schitt and nobody had any idea what it came off of and the #'s on the carb were gone as well...
I'll check this manafre place I reckon...
Thanks!
FE
Old 06-10-08, 09:22 AM   #6 (permalink)
ranger's Avatar
If you post a pic of the carb you have a better chance at someone helping you ID it.
More than likely if the carb was on a cruiser it is either a 32/36 or a 38MM carb, which are easy to tell apart. A local parts store will probably not have a kit for an aftermarket carb like a weber.
Once you ID the carb, then you can get the right kit. I think the last time I bought a rebuild kit for a weber I got it off ebay. Other places you can get a kit are JTO, Manafre, CCOT, and many others. Google is your firend!
ranger is offline   Reply With Quote
Old 06-10-08, 11:33 AM   #7 (permalink)
LIttle prob... I don't have 2 weeks....
The carb is a 32/36, the kit's only come with a acc pump dia. the missing dia is the power valve diaphragm and the elec. choke diaphragm....
I'm just going to fudge this entire rebuild and re-use what I cannot find locally.
Sumbicchin webber 40mm carbs are the on the shelf commodity at the moment... Redline don't answer teh damn phone and they're the tards that SELL the webber carbs to the consumer
Later and thanks for the tips guy's!
FE
Old 06-10-08, 12:16 PM   #8 (permalink)
THC
Trollhole's Avatar
TLCA# 15077
Garage
Weber Carburetors Carbs 40 DCOE 45 DCOE 32/36 32/34 Jeep. Top-End Performance 818 764-1901
Jeep Weber Carb Conversions
Trollhole's Crazy Forum
Marshall
Upstate Cruisers
Old North State Cruisers
TLCA
RIP Andrew Farmer
"What fits your busy schedule better, exercising 1 hour a day or being dead 24 hours a day?"
Old 06-10-08, 01:52 PM   #9 (permalink)
inkpot's Avatar
TLCA# 10338
Thanks!
FE
Howdy! The Rochester 2 bl was/is a popular carb swap. I had one on my 72 FJ40. Worked good. Tune up parts and settings were usually based on mid 60s chevy 6 banger pickup trucks. I always used 1966 and never had a problem. Rebuild is easy and parts should be common in most stores. It could be you can get it running faster than you can figure out the weber. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is online now   Reply With Quote
Old 06-10-08, 07:27 PM   #10 (permalink)
I called a guy today and ordered teh 32/36 DVsomething or other kit and will just have to wait....
Someone there (worked for redline) said they transition a few thousandths of secondaries, but factory is Zero...
LinkBack to this Thread: http://forum.ih8mud.com/40-55-series-tech/225656-i-need-little-advice.html
Posted By For Type Date
little kit cars | Hottags This thread Pingback 06-12-08 10:08 AM
