Old 06-05-08, 02:19 PM   #61
inkpot's Avatar
TLCA# 10338
Originally Posted by '74 UA FJ View Post
Would 2 inch tube, 1/4 inch thick be good enough for the arms on this type of traction bar?
Howdy! 2" might be a little overkill, but I also come from the school of "use what you got" fabrication. I built my front bumper from 3" x 1/4 tube that was free. The words "lightweight" and "Landcruiser" do not belong in the same sentence. I mean, like who's gonna see it, and who's gonna care? There's plenty of room for it, and the weight is down low where it is not going to hurt the center of gravity. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 06-05-08, 02:43 PM   #62
Roll Tide!
'74 UA FJ's Avatar
Originally Posted by John Smith View Post
I think 2" would be too large and a PITA to make a traction bar from. I made mine from 1.5" 1/4 wall tube and it has held up great.
I thought cam was using 2". Is that 1.5" he's using?
1974 FJ40 FI vortec 350, H42/Orion 4:1, 4" lift, 35x15.50 SXs on MRW beadlocks, lock-rited f/r, Saginaw ps, etc, etc.
1994 FZJ80 with lockers and 285 revos.
'74 UA FJ is offline   Reply With Quote
Old 06-05-08, 03:18 PM   #63
In the garage
John Smith's Avatar
TLCA# 9074
From the pictures it looks like 1.5 to me. Though I am sure he will post up what he is using.
79 FJ40 & 78 FJ55
http://users.starpower.net/johnsmith <- Detailed ToyBox install instructions
Please help save the Upper Tellico OHV area, Donate to the Rescue Tellico Fund http://www.sfwda.org/trails/tellico/donate.html
John Smith is offline   Reply With Quote
Old 06-05-08, 03:20 PM   #64
Roll Tide!
'74 UA FJ's Avatar
What's the diameter on a 40 driveshaft? That will give a little comparison. If there is plenty of room under there, which I think there is, I don't see a problem with using 2" tube. Probably a little bit stronger. 1.5" would definitely look better, though.
Old 06-05-08, 06:43 PM   #65
Brian in Oregon's Avatar
Can you post some pics of the bars when the axles are at or near max articulation?
1971 FJ40 w/ Chevy 350, Mark's of Australia bellhousing kit, 1979 4-spd transmission & transfer case, 12.50x33x15 tires. Rust free, original paint, wheel wells not cut.
Chit-Chat - Degrading the Ih8mud community since 2003.
Brian in Oregon is offline   Reply With Quote
Old 06-05-08, 07:33 PM   #66
camcruiser13's Avatar
1.75 tube
maybe a little overkill but it aint movin.
cc
76' fj40
camcrusier13 build threads the following are links, just click, go on try it
Traction Bar
Sliders
Ram Assist
Bumper Poison Spider Style
Shackle Reversal
Half Doors
if your doing it im sure ive done it, need help just ask.......
camcruiser13 is offline   Reply With Quote
Old 06-12-08, 05:11 PM   #67
yellowstoner's Avatar
TLCA# 16946
Dameron, Cameron! That was fun to read. Any chance you still have that roll cage or did you get sick of waiting for me?
'78 FJ40, 2F, 33x10.50 BFG's, PS, rear locker.
yellowstoner is offline   Reply With Quote
Old 06-12-08, 09:33 PM   #68
still got it, but i did move it outside, got tired of looking at it in the garage, im a phone call away.
i gotta finish this thing up and get some action shots
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-23-08, 10:53 PM   #69
okay well finally finished it up and took it for a run in the back fields,
took that camera along. here are some pics.
this is the johnny joint doing what its supposed too. worked out nicely
and another
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-23-08, 10:55 PM   #70
as you can see the rear was pretty twisted and all is well
one more
ignore all the wires hangin down gotta redo some trail lights etc, no biggie
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-23-08, 10:56 PM   #71
so there you have it. hope this will help some and appreciate all comments and opinions.
goodnight now!!!!!!!!!
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-23-08, 11:26 PM   #72
looks good. I broke my first one which had super thick tube like yours, but had a slip shaft of solid tube in the front to allow max rotation (no need for a joint or shackle)... The solid 1.25" thick cold steed busted like a piece of balsa wood after doing a burn out on a dirt road. Not only proof of a poor design or choice of materials on my part, but also stressed the point very well of how much torque is going on down there. Its an incredible amount.
My current one is similar to the one you just did, though I used RE's instead of a jonny joint - and works well. The axle side RE's allow the bar to direct the front attachment point a little easier under flex (wiggle side to side as the axle articulates). I would really keep an eye on where you connect the top bar to the bottom one though. As thick as that tubing is, you do risk folding that tube where they come together. Either after landing on it (mine has saved my drive line a few times), or from doing wheelies down your street.
cheers!
Dustin
dustin is offline   Reply With Quote
Old 06-24-08, 02:09 PM   #73
Looks good!
One comment...I had mine connected to the axle housing just like yours is. It ripped completely out of the housing. This was partially cause the cruiser housings being about 1/8" thick...and partially due to my driving. I ended up putting a few extra braces to help hold that bracket to the housing. That worked fine till I swapped in a dana 60 which has VERY thick tubes.
edit: what ripped it off was not noticing the whoopties at the bottom of a dune. I let off the gas but still got the front then rear then front then rear bouncing action. Sorta like a bucking bronco.
This design is really good in regards to not limiting articulation of the suspension. However, the limits on even suspension travel (both sides at the same amount and same time) is the drawback to this design. It binds up a bit. It works good for me most of the time cause I don't baja my rig (with the exception of those hidden whoopties).
Tankota is offline   Reply With Quote
Old 06-25-08, 11:23 AM   #74
i drive like grandma
especially after watching my buddy tear his rig to pieces,
i tend to save money by doing this
cc
76' fj40
Traction Bar
Sliders
Ram Assist
Shackle Reversal
Half Doors
Old 06-25-08, 02:00 PM   #75
inkpot's Avatar
TLCA# 10338
Howdy! Good logic. Spend more time driving, and less time wrenching, on the trails. That anti-wrap bar is mighty cheap insurance to prevent big problems plus it gives you some extra DS protection. Side benefit: now you can drive normal throttle in 2wd Low Range, for those easy to moderate trail sections. John
CSC #41
Mortgages | Cheap Gas | Deals On Products | Apple ipod | Mortgage Loans
